Transmission swap gone wrong (maybe), need help!
Old Sep 2, 2013 | 08:47 PM
jmc88runner's Avatar
Exclamation Transmission swap gone wrong (maybe), need help!
Hi, heres the scoop. I have a 88 3.0 auto, the trans went bad so I found a a340h from a 92. My friends shop did the swap. when I got it back it shift through all gears but it revs like 1000 rpms higher than it used to and the engine is always working hard to keep the car moving. on the freeway if i wanna go 65 im pushing 4000-4200 rpms. It revs about 1000 rmps higher than it used to. I changed the coolant sensor and made sure the thermo works. the trans got a new filter and fluids when it was swapped. I was thinking maybe its the TPS? maybe a 92 TPS is different from the 88s? If anyone has a suggestions or anything please let me know, Thanks guys.
Old Sep 3, 2013 | 11:05 AM
Sturmcrow's Avatar
Redacted. I do not know enough about auto trannies, so could very well have been wrong.
Old Sep 4, 2013 | 02:33 PM
Punchy's Avatar
Wonder if there is to much air in the torque converter.
Make sure the kickdown cable is not over tentioned.
The linkage between 1st and 2nd gen 4R might be different, Check the length on the posission selector on the old and new trans, You may need to swap then over.
All A340h are the same except for the speed sensor, 87-91 are cable 92-95 electric and possible selector levers.
Old Sep 8, 2013 | 08:57 AM
Thanks, the kickdown cables not too tight. Ill check into the speed sensor.
Old Sep 8, 2013 | 09:11 AM
Oh also I was stopped on a hill, when I went to gas it it slipped a little, I have like nothing when starting in 1st
Old Sep 9, 2013 | 12:28 AM
RSR's Avatar
RSR
Best way to tell is to start looking at parts diagrams I guess. I think there are the ECMs are different between those years. Not sure about all the sensors and whatnot... Talk to a tranny shop I supppose. They'll be able to point you in the right direction..
I think I'd look at swapping tranny sensors before anything else...
Old Sep 9, 2013 | 05:31 AM
j2the-e's Avatar
What is your stall speed? What is line pressure? Is overdrive working? Are there any trouble codes?
Old Sep 9, 2013 | 06:17 PM
oldblue's Avatar
have you checked the fluid level yet?
Old Sep 9, 2013 | 06:30 PM
dropzone's Avatar
Fossilized
What did your friend's shop say?
Was the trans from the donor 92 a proven good trans?
Sounds like fluid or torque converter to me.
used transmissions are a crap shoot in my opinion. I have had two good used transmission s and one that was a waste of time to install.
Old Jan 9, 2014 | 10:03 PM
Thanks for all the help guys, I still don't know whats going on with the trans still but I might have found a manual trans from a 94 I might try swapping out. I just want my car to run again, anyone know of a toya guy in the la area that I could take it to?
Old Jan 10, 2014 | 05:46 AM
Gevo's Avatar
My car is at a tranny shop now. I'll let you know in a few more days if you should go there.
Have him take a look and tell you if it' s alost cause or if you could make it work still.
Kings Transmission, got a lot of good reviews online.... of course most of the reviews said "he's a really nice guy and now my car works".. so they aren't very technically inclined customers... lol.
but, from what i've gathered a manual swap isn't all that quick or easy. Search the forum, there are a few threads that discuss it.
mskalmus
May 28, 2017 07:51 AM
1996Taco
Jul 20, 2015 12:02 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
