Transmission
Transmission
Hi All
I have a 92 T4R 4WD 3.0 V6 Auto.
It seems to be taking a lot longer for the transmission to warm up (ten minutes longer) and shift to the higher gears. Even though the outside temp stays 75-92.
Could the engine temp sensor be causing this?
I have been having cold start problems for a few months.
But the transmission problem just started this week.
It had a atf drain and fill about 6 weeks ago.
have the same problem with my A340H (same transmission you have) behind my 3.4
fluids fine. but it takes 2-5 min for the tranny to shift up. until then you drive wrapped out. im thinking its a solenoid issue but im not sure my tranny has 300+k on it
TheBFA
Feb 15, 2020 06:55 AM
Odin
Sep 26, 2015 06:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
