trailrunner vs. prerunner
Old May 23, 2007 | 09:05 PM
Yota82's Avatar
Originally Posted by 2WDoffroadx
YOTA82, how the hell did you build the arms yourself? If the angles arent percisely accurate, it'll throw you off. How'd you get the right angles down?
You basicly use the stock angles and extend them. You can make a jig out of extended arms and make a final tubular a arm. This is not my jig but here is a pic of a LT Toyota jig. You get the idea. LT kits use the same angles as stock but wider. Pretty simple but a lot of work. I bought the parts slowly over a years time, that way it was not such a price shock. It took a long time but I am more than happy with it. I live in Ventura, CA. but I grew up in the desert riding dirtbikes. I love the desert and once I figured how to make LT kits and how easy it was I enjoy it more than ever.
Old May 23, 2007 | 09:08 PM
2WDoffroadx's Avatar
Whoa, thats an awesome idea. I'm in Fullerton/OC if you know where that is.
I want to take my rig through some beginner trails if you know of any..
pinnacle's Avatar
Both of those Yota's are sick.
PINNACLE how do you have a limited slip on a IFS? NIIICE rig though, man. The fenders lookawesome. TOUGH little piece of machine.
I'm 4wd. I had the front diff replaced with one that had gears and a limited slip when I had the kit installed.
Old May 23, 2007 | 09:13 PM
Wtf? I thought you need a diff to have locking/limit slip gears...
Let alone, gears at all!
I thought IFS 4wd wheels get power directly from the tranny.
Opposed from the Tranny, to the Diff, to the axle..
Old May 23, 2007 | 09:47 PM
  #25
runnerfreak88's Avatar
wait so how do you figure out how to route the tubing im very interested in making my own a arms. so it looks like you just extend the ball joint from the stock position. how do you figure how long they need to be
Old May 24, 2007 | 05:46 AM
  #26
sh0kk86's Avatar
go take off your skid plate and look around at your ifs some, youll learn a lot
Old May 24, 2007 | 06:31 AM
  #27
pinnacle's Avatar
Thats how the rear axle gets it power. The front gets its power from the transfer case.
Old May 24, 2007 | 06:54 AM
  #28
norcalsvx's Avatar
Originally Posted by WCorbett
Hey norcalsvx i have the 26 downey t-bars and are to still for flex but good for high speed and I want to do both. are the OME bars stiff enough to do like 50 offroad without bottoming out and do they flex alright? thanks for your help. maybe well meet up at greenhorn sometime.
yea it is stiff enough to bomb down fire roads at 50, yea i need another greenhorn run
Old May 24, 2007 | 06:58 AM
  #29
norcalsvx's Avatar
Originally Posted by Yota82
Here is an old pic of my truck from when I first made the LT kit.
I literally built the kit and hacked up the fenders and drove it to Mexico with zero test time and went to the San Felipe 250 a couple years ago, drove a lot of offroad miles in a foreign country. I didn't have any problems but a thrown alternator belt.
Specs:
*Home made upper and lower a arms
*3.25" wider per side
*Strategicly placed low profile droop and bump stops
*Made of .188 wall DOM gusseted with 1/4" and 3/8" plating
*10" stroke 2.5" dual rate King coilovers with remote reservoirs
*TC lower uni-ball conversion
*TC shock hoops
*16" of wheel travel (front diff removed to not be limited by CV's)
Total cost was less than 2K (mostly shocks $1300)
In the last couple years I added the TC idler arm. I gusseted the center link and pitman arm and switched to heim steering and 62" Deavers. I wish my digital camera worked so I could take some current pics as a lot has changed. 280K 22RE.
are those bfg baja's, and are you running 4wd in this pic?
Old May 24, 2007 | 07:02 AM
  #30
Sonofmayhem's Avatar
Originally Posted by deathrunner
Bye Bye CV's
locked front, 35's, and a supercharged 3.4 through double low range reduction...... OUCH!
Drive cautiously.
duh arb it will probably never go on. its there for the cool factor, plus the truck wont come till like 2010
I really like yota82's old truck, i would like to do something similar but will probably do a 3rd gen truck.
Old May 24, 2007 | 07:08 AM
  #31
no silly goose, each 4wd, not awd, has two diffs, one front and one rear and they send the power to the wheels
Old May 24, 2007 | 09:45 AM
  #32
KevinInSac's Avatar
Originally Posted by norcalsvx
i love the pre runner's (death runner's is bada$$) rock crawling is just waay to slow and boring to me but i live near the rubicon so i do a little of it, but the desert is where my heart is (san diego east county boy)
my set up is budget till i can get the TC kit
Ah, I knew we had something in common, I just forgot what it was. I was raised on desert runners. Lived in SD till about 96-97. So I love the desert scene, but the rock scene is a bit cheaper and more common around this neck of the woods.
Old May 24, 2007 | 10:41 AM
  #33
norcalsvx's Avatar
yea i lived in alpine for 25 years and down in OB for 3, i've been wanting to check out some nevada dunes pretty soon
Old May 24, 2007 | 11:58 AM
  #34
KevinInSac's Avatar
Hey, what's this greenhorn I've been hearing about? I know it's somewhere in GV, but I don't know where, how to get there, and what exactly is there...
Old May 24, 2007 | 01:15 PM
  #35
norcalsvx's Avatar
some good info for greenhorn
http://www.pirate4x4.com/forum/showt...=555261&page=3
Old May 24, 2007 | 04:31 PM
  #36
Only 4wd have a transfer case, right?
Old May 24, 2007 | 04:53 PM
  #37
Jay351's Avatar
^ correct. There would be no need for a transfer case on a 2wd
Old May 24, 2007 | 04:56 PM
  #38
I thought so. I got scared for a minute because i wouldnt have had the tran case re-oiled for years. haha
Does anyone know anything about the Fabtech Ivan Dan LT kit? Are they good, bad, ugly? I am looking into them and want to know everything they include?
Old May 24, 2007 | 06:09 PM
  #39
ewong's Avatar
Is Fabtech still making the Ivan Dan kit?
Off the cuff I think its the suspension parts but not the fenders or shocks...
I ferget if it has the weld on shock hoops or thats an "accessory" item.
I recall it was basically the "extended a arms and lower strut rod parts"...
Isnt the info on the fabtech site?
Old May 24, 2007 | 06:43 PM
  #40
Yota82's Avatar
No they are definantly not BFG Baja's. I dont recommend that tire for regular people. They are expensive and are a race tire, the tread is soft, they have horrible tredwear, and if you park your truck for a day or so they develop really bad flat spots that will jar your body until the tires heat up and become round again. Oh yeah, did I mention the price? There is a thread from a couple months back called "Pick your favorite BFG tire" that I ranted about them too. No I didn't have 4WD in that pic.
