tps switchup?
Old Apr 8, 2016 | 07:33 PM
firewood bandit's Avatar
tps switchup?
I just bought a '90 22re pickup. I've been having some tps issues: i went through the adjustment procedure, got it reading the correct ohms, I would tighten the screws, check it again, fine, come back an hour later and it would be out of spec. so I ordered a new one, denso, from 22re performance, which he matched to my vin. I went to put it on today, and wala! the dog ears coming from the throttle body are 90 degrees off! clearly this is not the original throttle body or engine. and it's friday, and i'd like to get 'er rolling before i can return/exchange this part. my question is, can I reposition the drive sprocket on the TB 90 degrees to match this tps? and if so, will this be compatible with the ecu?
Old Apr 14, 2016 | 01:04 PM
MudHippy's Avatar
In my experience, the physical mismatch is telling you something. Don't even try it. It won't work, and you can't make it work. Most likely they aren't even electronically compatible. So messing with the throttle body to make it fit will probably get you nowhere. They're trying to prevent you from doing something stupid.
Old Apr 16, 2016 | 06:45 AM
wyoming9's Avatar
Red face
I must have super good luck I have never had to ever mess with these other then the first initial check when the vehicle shows up
One finds really different things at times.
brianroland97
Jul 8, 2020 09:06 AM
crawler85
Feb 27, 2016 07:31 AM
Calioutdoor
Feb 17, 2016 08:56 AM
95_n130
Feb 12, 2016 11:11 AM
IMCOLOR
Jan 31, 2016 04:51 PM
