TPS Question
Old Sep 22, 2008 | 01:01 PM
nolimit's Avatar
TPS Question
Can the tps be taken apart and cleaned. I had a thread last week about a code 51 I was getting on a newly rebuilt 3.0. This truck sat for 6 yrs before I bought it and rebuilt the motor. It will crank as long as I pat the accelerator but just revs up the loses power then revs again. I think it's the tps. I pulled the throttle body last night and am going to start cleaning it today. Just wanted to know if you could clean the tps also.
Thanks
Old Sep 22, 2008 | 01:16 PM
blackspyder's Avatar
unplug the TPS and see if it will rev up all the way. Had this issue yesterday with my 88 pickup 22re and I unpluged the TPS and it worked fine (I know mine is shot, I acid cleaned the whole intake and throttle body and fried it) Also check for a short at the MAF (when I did the intake swap I forgot a wire and it would crank, rev, then die)
Old Sep 22, 2008 | 01:23 PM
nolimit's Avatar
Thanks will try those. I've got to get the throttle body back on now.
Old Sep 22, 2008 | 01:46 PM
abecedarian's Avatar
the tps cannot reliably be cleaned. you may be able to remove it from the TB and use an electrical contact cleaner on it but I wouldn't gurantee it will work afterwards
if the engine will rev up high then stall but begin revving up again just before it completely dies, it's usually a significant vacuum leak so check the intake manifold, hoses and ducts for any leaks / cracks or missing hoses.
Old Sep 22, 2008 | 02:01 PM
nolimit's Avatar
Thanks will be checking.
Old Sep 22, 2008 | 03:07 PM
nolimit's Avatar
Okay while checking tps with ohm meter I'm not getting the readings I should per the chart I have. So I removed the tps and you can rotate by hand but it does not spring back. As for the ohm readings they are not off much. Any suggestions.
Old Sep 22, 2008 | 03:08 PM
if it doesn't spring back, it's bad.
Old Sep 22, 2008 | 03:11 PM
nolimit's Avatar
Okay that's what I thought. Any place best to find one other than dealer.
Old Sep 22, 2008 | 03:13 PM
put one from autozone (was about $80) on my 88 and it's gone about 10k miles without issue
Old Sep 22, 2008 | 03:17 PM
nolimit's Avatar
Thanks so much for your help. I see your cleaning up after Ike. I will be headed through Houston Friday night or saturday morning on my way to Mcallen TX this weekend to visit wife's family. Hope everything gets back to normal for you soon. Thanks again
Old Sep 22, 2008 | 03:21 PM
We trucked in here from California to help with some stuff. I'm down in the Beaumont / Nederland area at the moment. Things are pretty tore up here.
Good luck on the truck!
Old Sep 22, 2008 | 03:38 PM
nolimit's Avatar
I'm from lower Alabama (aka L.A.) born in pensacola,Fl We know the kind of destruction those things can do. Will be passing through Beaumont on I-10.
As Far as the truck can't wait to get it going my first Toy. Actually body in great shape. Any thanks again
Gone Fission
Jan 12, 2023 10:34 AM
Blamalam
Mar 12, 2022 07:34 AM
Sidherish
Aug 3, 2015 07:17 PM
Gone Fission
Jul 31, 2015 03:58 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
