Toyota pu 3.0 running slugish
Old Sep 21, 2017 | 07:18 PM
Marcos Espindola's Avatar
hi im new to the toyota world and im having a problem. I bought a 90 pickup and it was running fine drove it all day this past saturday and drove like a champ but on monday when i tried using it it started to run sluggish. When i would shift to second i would push on the gas and would barely pickup speed and if i would floor it it wouldnt go. Please help checked compression and spark plugs and everything is good
Old Sep 21, 2017 | 07:32 PM
scope103's Avatar
Codes? (Is your CEL - Check Engine Light - on?)
Old Sep 21, 2017 | 07:34 PM
No its not thats what has me more confused
Old Sep 21, 2017 | 08:27 PM
ksti's Avatar
I pretty sure scope103 was also asking if there are any codes stored in the ECU (computer).
You didn't alert to that.
Just curious.
Old Sep 22, 2017 | 07:10 AM
Just curious.
The only code it gives me is 51 but i think thats for auto trans. But not sure. Another thing was i degreased the engine and washed it down could water have ruined my distributor?
Old Sep 22, 2017 | 07:30 AM
ksti's Avatar
There are actually three concerns that code can pertain to.
Code 51: Switch signal - closed throttle position sensor (CTP) switch OFF during diagnoses.
Signal switch AC-switch on during diagnoses.
Switch signal-park/neutral position (PNP) switch not in P or N during diagnoses.
I suspect if its running "Sluggish" then you need to check your TPS to see if it is out of spec.
Old Sep 22, 2017 | 11:19 AM
yeah ima ohm out the tps once im home from work any idea what the readings are supposed to be? and i hope its that and not the distractibutor bcz it idles fine just runs like crap at low rpms when in gear and after like 2500 (estimate bcz dont have rpm gauge) it runs perfect
Old Sep 22, 2017 | 11:55 AM
ksti's Avatar
Honestly the procedure for testing and adjusting your TPS can be a little tricky and confusing if you have never done it.
But that's the challenge when working on a 3VZE, it can be frustrating but rewarding.
If you plan on keeping it, get yourself get a repair manual, (FSM) you can perform test procedure's and diagnose problems.
There are plenty of TPS adjustment "how to" on the internet.
Distributors are not a common problem, I have seen alot of them replaced for unrelated reasons.
Here is one to get you started.
http://www.lcengineering.com/.../pdf...Adjustment.pdf
Old Sep 22, 2017 | 03:49 PM
Im a little scared on doing it bcz idk if im doing it right
