Toyota gremlins 3.0 issue.
Old Dec 10, 2015 | 04:21 PM
Edionne13's Avatar
Here's what has been done.
New spark plugs
New Distributer and cap
Spark plugs are fine.
New fuel.
Flame thrower Injectors
Here's the back story. 10 months back my 93 blew headgasket. Long behold. I finally got around to replacing it. Swapped in a good block from 91 4 runner. Have had this run once ran bogged down. Timing was off.
(Hoses on passenger side were mixed up) timing was off at this point. So in essence we look up diagrams of the hoses got that figured out. timing is good.
There is spark. And there is fuel going to engine. Tries to turn over but won't start. Alternator and starter are fine. All connections are accounted for. Been staring at this problem for few days now and I'm at a loss.
Old Dec 10, 2015 | 05:24 PM
89Hilux's Avatar
Hooked up a fuel pressure gauge?
Old Dec 10, 2015 | 05:41 PM
millball's Avatar
Checkd for codes??
Old Dec 10, 2015 | 05:43 PM
Edionne13's Avatar
Originally Posted by millball
Checkd for codes??
No on fuel pressure Guage and doesn't throw any codes.
Old Dec 10, 2015 | 06:46 PM
DrCreosote's Avatar
This is probably just a noob response, but I discovered that these things won't start at all if the air induction system is interrupted. It has to go through the mass air flow sensor or it just cranks and sputters.
It took me a new set of injectors to realize this, but what the heck, I needed them anyway.
Old Dec 10, 2015 | 07:14 PM
Edionne13's Avatar
Vmaf is connected. Maybe I'm not understanding your respone. These injectors only have 3000k miles on them and worked perfectly before . There isnt any leaks with the injectors. I do have the original set that came with the block. But doesn't seem plausible or needed to swap then over
Old Dec 11, 2015 | 02:49 PM
89Hilux's Avatar
I think he's saying bust out a dmm and try to teoubleshoot it some
Old Dec 13, 2015 | 08:54 AM
Edionne13's Avatar
Good news ... throws a code 12 now which I did look up. But would someone like to expllain what I'm supposed to do...
Old Dec 15, 2015 | 07:14 PM
justin_4runner's Avatar
did you forget the bolt that holds the dist. rotor on? maybe no spark to all plugs.
just saw one where the guy was getting this code and his dist. was not moving. im assuming your is moving but might want to check it.
Old Dec 16, 2015 | 05:11 PM
Edionne13's Avatar
Has spark. that bolt is in. I replaced ingnition coil today and still throwING code 12
Old Dec 16, 2015 | 05:56 PM
did you hook up both ground wires, one on drivers side and one on fire wall?
Old Dec 16, 2015 | 07:35 PM
Edionne13's Avatar
wouldn't it just be passenger side fender wall one from battery then the upper intake where it says 3vze 3.0 clips in to firewall. Yes both connected
Old Dec 16, 2015 | 08:11 PM
mine also had one on driverside that was from the coil area to head, followed the coil wire. i had one fry and wouldn't run. i had to replace it to get the 4runner home. thats what made me think of it, if im also not mistaken u should have one from battery to motor mount area that was a larger in size.
rubrsidedwn
Jul 7, 2016 07:28 PM
Brandon H.
Dec 5, 2015 09:17 PM
Jamie Flores
Oct 10, 2015 01:12 AM
SCZIG
Sep 20, 2015 09:00 AM
matt1833
Sep 16, 2015 07:11 AM
