Toyota Axle Swap on Mazda B2200
Sick of the terrible aftermarket support for mazda so I'm planning on swapping in a rear end from a 86-95 truck/4runner and throwing in a locker. trying to gather some info to make sure everything will work.
I'd like to come out with an axle that is spring under, 6 lug, with the toyota 8" diff.
Looking for the distance between the (toyota) rear leaf perches center to center.
From what I've gathered:
All 4x4s are SOA, 2wd is spring under
4x4s are 6 lug on 5.5
2wd are 5 lug
So does this mean I'm gonna have to grind off and weld on new leaf perches underneath a 4x4 axle to stay with 6 lug?
The v6 2wd axle sounds like a potential as it has the 8" diff but its 5 lug, are there 6 lug conversion kits available?
2wd are 5 lug
new axle perches http://www.ruffstuffspecialties.com/...TOY-PERCH.html and if you use the coupon code DEARWIFE you get 17.5% off your order for black friday.
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
RaginAsian91
Jul 27, 2015 07:11 PM
