Toyota Axle Swap on Mazda B2200
Old Nov 21, 2012 | 08:28 PM
Digital Philosophy's Avatar
Sick of the terrible aftermarket support for mazda so I'm planning on swapping in a rear end from a 86-95 truck/4runner and throwing in a locker. trying to gather some info to make sure everything will work.
I'd like to come out with an axle that is spring under, 6 lug, with the toyota 8" diff.
Looking for the distance between the (toyota) rear leaf perches center to center.
From what I've gathered:
All 4x4s are SOA, 2wd is spring under
4x4s are 6 lug on 5.5
2wd are 5 lug
So does this mean I'm gonna have to grind off and weld on new leaf perches underneath a 4x4 axle to stay with 6 lug?
The v6 2wd axle sounds like a potential as it has the 8" diff but its 5 lug, are there 6 lug conversion kits available?
Old Nov 21, 2012 | 08:37 PM
BigBluePile's Avatar
Depending on the axle length, 4wd vs 2wd, why not use the 2wd axle housing with 4wd axle shafts?
TrikeKid's Avatar
You'll probably have to weld new perches on since the angle and mount width working in your Mazda is doubtful to begin with. Just grab a 4x4 axle and do the swap.
Old Nov 21, 2012 | 10:15 PM
westjohns yota's Avatar
seriously, and dont do a spring under, do it how toyota came with, spring over, factory toyota housing, just change the utput on your trans, alot easier.....
Old Nov 22, 2012 | 05:43 AM
Spring over is gonna give me more lift than my ifs front can handle as far as I can tell. Isn't it usually around 4 - 5"?
Old Nov 22, 2012 | 05:44 AM
Robert m's Avatar
new axle perches http://www.ruffstuffspecialties.com/...TOY-PERCH.html and if you use the coupon code DEARWIFE you get 17.5% off your order for black friday.
Hatch man
May 17, 2026 11:40 AM
vasinvictor
Jan 20, 2016 12:39 PM
RaginAsian91
Jul 27, 2015 07:11 PM
Gravel Maker
Vendor Advertising
Jul 2, 2015 12:57 PM
Ott47
Jun 26, 2015 05:21 PM
