Top alternator bracket bolt?
Old Aug 24, 2018 | 01:06 PM
Jakez's Avatar
Trying to remove the stock top bracket to install gm to toyota alternator bracket kit. I've taken off the far left bolt (if you're standing facing the truck) and the sliding adjustment bolt and it seems some thing is still holding it on, is there another bolt somewhere still holding it or am I just not yanking hard enough??
Old Aug 24, 2018 | 03:35 PM
Co_94_PU's Avatar
Yeah you missed some probably. All those brackets are layer on top of each other and interconnect from what I remember, just about everything in that corner of the engine needs to be loose.
Three on the front one in the back, and the PS pump and water inlet are in the way.
Old Aug 25, 2018 | 05:28 AM
Paul22RE's Avatar
5 Year Member
There are 2 bolts for that bracket. One facing forward (which you found), and one facing the driver's side attached to the block hidden by the water intlet pipe.
shafner30
Dec 22, 2016 07:52 AM
breakthastatic
Jun 2, 2016 09:56 AM
dropzone
Mar 20, 2008 04:57 AM
freshman
Jan 31, 2008 05:13 AM
hotel triple nickle
Aug 25, 2003 05:01 PM
