Toolbox CB Mount..
Old Oct 29, 2008 | 10:03 AM
Trustyrusty's Avatar
Toolbox CB Mount..
Anyone know where I can get a mount for my CB Antenna (4' Firestik) to mount to a toolbox? I took my rollbar out cause it got in the way and I need a toolbox more than that.. So I'm putting my toolbox back in but neet a mount for my CB antenna cause my antenna is rail mounted..
Old Oct 29, 2008 | 10:06 AM
andtheman1988's Avatar
Radio Shack has them, or check at your local truck stop they should have everything you need.
Old Oct 29, 2008 | 10:07 AM
ryantowry_81's Avatar
i have always used the clamp on mounts they use on semi trucks and loose the backing plate and just drill four holes in the box, always worked well.
Old Oct 29, 2008 | 10:23 AM
Aight.
Old Oct 29, 2008 | 10:32 AM
georgiayota's Avatar
I have mine mounted on a piece of 2in square tubing that i bolted to the toolbox. I bought one of those rail mount L brackets and bolted to the square tubing. I use the square tubing because you want the antenna to be atleast an inch and a half from any metal.
Old Oct 29, 2008 | 12:54 PM
abecedarian's Avatar
the clamp on with the four bolts drilled on a vertical surface is probably the most stout solution you'll find. the mounting stud, where you just drill an appropriately sized hole and through-bolt it on are good only with thicker metals since the antenna will whip around while you drive.
Old Oct 29, 2008 | 01:56 PM
Jay351's Avatar
Just a note, I read in the FSM that you should keep componants for a CB radio as far away from the ECM as possible..
Old Oct 29, 2008 | 03:20 PM
Thanks Jay, but thanks for (RUBBING IT IN MY FACE!) that I don't have EFI.. I wish I had EFI, but then again I've never had any carb problems..
Old Oct 29, 2008 | 03:23 PM
bet you have an ecu though.
Old Nov 1, 2008 | 11:09 AM
Find it for me then! Haha I'd rather not look.
Old Nov 1, 2008 | 01:40 PM
Jay351's Avatar
Well then, giver!
Nickdigg
Jul 7, 2015 06:04 AM
crappled
Dec 3, 2005 09:14 PM
Tacoma Dude
Oct 4, 2003 01:14 AM
