Tire/Gear ???
Old Mar 1, 2008 | 02:05 PM
YeloSub7's Avatar
Tire/Gear ???
Alright, well I have a 90' 4Runner 22RE 5speed now to work on
Going to be installing some cruiser coils and bj spacers next week
I want to run 32s instead of cramming 33s under there so I don;t have to deal with rubbing and more mods/lift... anyways I was wondering what gearing I should use (4.10s atm) 4.56 or 4.88 with my engine/tranny setup? Not many 2nd gens on here with the 4 banger, but anyone with help or ideas will be greatly appreciated!
As of right now I don't need to dd it, but it may be that down the road... sorry to be difficult
Old Mar 1, 2008 | 02:14 PM
Jay351's Avatar
Go with 4.88 gears. You will rev higher then stock, but you will have more lower end grunt. Great for accelerating or passing.
Old Mar 1, 2008 | 02:56 PM
elripster's Avatar
I'd go with 4.88's too. Plus, should you ever decide on 33's, while it won't accelerate as quickly, you will at least have the option.
Frank
Old Mar 1, 2008 | 05:12 PM
YeloSub7's Avatar
good point... will I still be able to drive at hwy speeds (65mph) without reving too high tho? I just know that 4.56 gears from other stock toys are easy to find compared to 4.88. And I don't wanna pay the big bucks to have new ones installed, and I've never done those myself and don't know if I trust myself with something that delicate. Sounds like I should just be patient and get 4.88's then... thanks for the info
Soooo, anyone have any 4.88's?
Old Mar 1, 2008 | 05:17 PM
GenXr's Avatar
I have a front 4.88 R&P I'll sell you.
Old Mar 1, 2008 | 05:34 PM
YeloSub7's Avatar
Sweet! pm'd ya...
Old Mar 1, 2008 | 05:35 PM
YeloSub7's Avatar
Or should I still go with the 4.88's and go with the 33x10.5? Or will I really gain much with those over 32x11.5?
Old Mar 1, 2008 | 05:44 PM
YeloSub7's Avatar
sorry one more ? If I go 33x10.5 I will probably go with the rims I have on now, but if I go 32s I was thinking of using some other rims that are 15x8 with 3.5 or 3.75 backspacing, cant remember... any thoughts of rim size for either tire? Well, as far as clearance/rubbing issues?
Old Mar 1, 2008 | 06:11 PM
GenXr's Avatar
If you run 4.88 gears you'll be happier with the 33's all around.
Old Mar 1, 2008 | 07:58 PM
YeloSub7's Avatar
AH!! I don't know what to do... I am leaning more towards running 32's, any more thoughts from anyone else before I bite the bullet and just buy these 4.88's from GenXr
Old Mar 2, 2008 | 01:19 PM
YeloSub7's Avatar
so would 4.88's be ok with 32's? With a 22re & 5 speed on this 2nd gen? As a dd?
Old Mar 2, 2008 | 01:40 PM
Jay351's Avatar
Yes, it will be fine.
If you go with a rim with less backspacing then stock (4.75) you might run into rubbing issues depending if you run a wide wheel/rim combo.
If you can, find some factory 4.88 gears from a automatic 4runner or truck (with factory 31" tires) They can be had pretty cheap, and are stronger then any aftermarket R&P you can buy.
go with 4.88's with a 32-33" tire, no matter the width. It will rev a little higher, but thats okay. If you were driving at 80mph all the time then you would want 4.56 gears.
Old Mar 3, 2008 | 02:52 AM
YeloSub7's Avatar
Thanks MATT! So I got a 4.88 rear third with a limited slip, no I need a front 7.5 ifs third... anyone? preferably open.
Old Mar 3, 2008 | 05:32 AM
Fizboy's Avatar
I run 33x10.5 15 on stock rims and no BJ spacers with minimal rubbing on the sway bar. I have 4.56 stock gears, but of course I have the V6 with a tiny bit more power but you have better torque. I like the thinner tire for the eastern mud and such. They do great for the long highway drives as well. The 4.88s will be better with the 4 banger and 33's. More low end torque for off road.
Old Mar 3, 2008 | 04:38 PM
Alindqu1's Avatar
how is the power with the v6 with 33 and 4.56?
Old Mar 4, 2008 | 12:17 PM
YeloSub7's Avatar
I ran this same setup on my old 94' runner, and it wasn't too bad, but the gas mileage suffered... I would still go with 4.88's, but as far as power it still wokred fine for me
Old Mar 4, 2008 | 12:35 PM
alpine4x4's Avatar
I ran the stock 4.56 gears with the V6 pickup 5 speed and 35" BFG mudders and it ran just fine.
Guyechka
Jun 16, 2010 02:57 PM
cpizzle42
10
Dec 17, 2009 09:38 PM
teamjbl
Nov 24, 2007 11:49 PM
