Timing cover bolts 1990 22R
Old Jan 15, 2024 | 04:41 AM
Tabaka45's Avatar
I am replacing the timing chain, guides and cover. The bolt chart shows 4 m10-60 bolts, the top two corner bolts, the right bottom bolt, and a bolt on the right edge just under the water pump. However, the bolts I removed are significantly longer, apparently because of the a/c bracket, p/s bracket and air pump bracket. Is there any information on the actual lenght of the bolts that go through these brackets?
Old Jan 15, 2024 | 06:55 AM
Jimkola's Avatar
YT Community Team
5 Year Member
This video will walk you through.
Old Jul 14, 2024 | 09:59 AM
Leviathan468's Avatar
JUICE222
Oct 13, 2015 08:50 AM
xxxtreme22r
Oct 15, 2009 07:33 PM
toyaholic
May 22, 2006 09:35 PM
needayota
Mar 28, 2005 06:51 PM
