tight valve clearance cause low compression
Old Apr 21, 2006 | 07:23 PM
jjenks0's Avatar
I have been tearing into my 91 3.0 because a compression test showed no compression on number 6 or number 1. I got the valve covers off tonight and there is not clearance on ( i cant remember ) several of the valves in the engine. Of course being not a through mechanic I did not do the leak down test but most of the cyliners were at 120 - 130 lbs. What I am wondering is do I do a valve adjustment and put it back to gether hoping that is the problem or do I go ahead and tear the heads off to see if any of the valve are burnt? I plan on measureing them again tomorrow and recording a much more accurate reading.
Old Apr 22, 2006 | 05:29 AM
Flash319's Avatar
I would make sure that there is clearance (to much is better, at least you know the valves are closing) then do a comp test. If you still have no compression I would say your head gaskets are gone.
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
montanatruck
Feb 26, 2017 07:07 AM
RatOmeter
Oct 22, 2015 03:17 PM
thefishguy77
Jul 30, 2015 10:59 AM
