Throttle Return Spring
Old Jan 24, 2010 | 12:45 PM
cgeorge's Avatar
Question Throttle Return Spring
I need a stronger throttle return spring. I noticed my throttle stuck a few times over the last few months and I have found that the stock return spring is pretty worn. I have my truck apart doing the HG and would like to replace the stock spring.
Where can I get one? I've searched but haven't been able to find anything as a replacement.
Is there something I can use in addition to the stock spring? I'm looking for a way to hook something up but haven't been able to figure how I can add something.
Thanks.
Old Jan 24, 2010 | 04:31 PM
bugs1961's Avatar
I think it's unlikely you find a new spring by itself. You could go to a junkyard and try to get one off an engine.
Old Jan 24, 2010 | 05:35 PM
RustBucket's Avatar
Your problem may actually be that the bushings on the throttle pivot are worn. That's the issue I've been having.
I took my throttle spring (the extension spring, not the torsion spring) to the hardware store and found one that was the correct size and range and was stiffer. Just had to nip the ends a bit to make it fit.
Also check that your dashpot is working properly. If the boot is worn crap can get in the plunger and cause it to not come all the way down.
Old Jan 24, 2010 | 05:54 PM
peow130's Avatar
You might try lubing up your throttle cable, too.
Guys, he's carbed.
Old Jan 25, 2010 | 02:57 AM
cgeorge's Avatar
Thanks for the tips - and yes as peow130 pointed out - I'm carbed.
I'm going to take the whole assembly out and clean it up a little better than I have already. I'll also probably take it to NAPA or my hardware store to see what they might have.
Old Jan 25, 2010 | 10:24 AM
86yota2wd's Avatar
I have the exact same problem.... it gets really bad when you are trying to stop in 6" of snow and you just lock up because you have to much gas going... and scary!! I need ideas too.
Old Jan 25, 2010 | 01:31 PM
cgeorge's Avatar
cleaned everything really well today and it seems better... it was a lot dirtier than it looked... that backside of the motor seems to really get nasty..
Old Jan 25, 2010 | 03:05 PM
peow130's Avatar
Mines only gotten stuck when it's EXTREMELY cold out.
Jun 1, 2021 01:51 PM
I8URSVT
Sep 3, 2015 11:42 AM
Blamalam
Aug 16, 2015 12:29 PM
mtc1105
Aug 4, 2015 08:06 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
