Thoughts?
Old Apr 14, 2020 | 08:49 AM
dh12791's Avatar
Thoughts?
What do y'all think of using Eastwoods 2k epoxy primer in a spray can with extension wands to spray inside my boxed frame rails after frame has been dipped? Ideas of other methods? is brushing epoxy primer easy enough if mixed then snaked through frame rails with sponges/brushes? what would be the best method?
Old Apr 14, 2020 | 10:06 AM
Mr. Z.'s Avatar
Why would you need to top coat the frame after it's dipped?
I've used the 2k epoxy primer on the "bed" after repairing holes, but not as a top coat.
Here is what I used on the inside of the frame:
https://www.eastwood.com/eastwood-in...z-aerosol.html
After prepping the surface, I hit the outside of the frame with Eastwood Rust Encapsulator and top coated with their Cassis Black.
Old Apr 14, 2020 | 10:35 AM
dh12791's Avatar
Dipped meaning acid dipped/stripped
Old Apr 14, 2020 | 11:12 AM
Mr. Z.'s Avatar
If I were attacking this again, I'd use the steps I outlined above.
It was affordable, looks good, and is lasting very well.
Cheers
The Wizard
Sep 1, 2015 11:48 PM
black_taco
Aug 3, 2012 12:32 PM
NO2HEAD
Sep 12, 2011 01:00 PM
betelnut
May 31, 2011 05:56 AM
4runnerguy
Jan 13, 2008 07:35 PM
