Is there an Idle Increase solinoid?
Wondering if the 22re is equipped with some sort of idle increase solinoid when an electrical load is placed on the motor? Just noticing that i will get a bit rougher idle when i have my headlights on in the AM and a noticeable lower idle when i lower the tailgate window but keep my finger on the down button even though it is all the way down.
I got the wires already upgraded. I did up the idle a bit, it was pretty bad at times before, i jsut noticed that when i add power, it goes down, doesnt stall. I actually added a bit of RTV to hold the screw in place since it seemed to be a bit loose. It really jsut seems to be a problem when the engine is warmed up. Drives fine but it had the rough idle. Just curious bout an idle solinoid for that. I knew there was an AC one. But i will keep searching.
Thanks!!
Thanks!!
Blamalam
Mar 12, 2022 07:34 AM
noosh
Aug 21, 2015 03:49 AM
