Temperature gauge
Old May 8, 2020 | 05:14 PM
DOWORK619's Avatar
Temperature gauge
Hello everyone, new member here. Just bought a 93 Toyota pickup 2wd manuel. (Had to get it towed home) lady I bought it from had it sitting for almost 5 years since it couldn’t pass smog, she didn’t really have a lot of details on the truck but I decided to buy it anyways. I put a new battery and it started right up, I noticed the temperature gauge shoots straight to HOT, even when I turn the key on, it had been sitting all night so there’s no way it can be overheating, I changed the temperature sensor and sender as well and no luck, I checked all wiring and all grounds to make sure everything was connected correctly and it was, I’ve spent countless hours trying to figure out the problem, I pulled the cluster out and checked all wires behind it and replaced the temperature gauge and still no luck. Hoping you guys can help a new member out.
Old May 8, 2020 | 05:57 PM
Paul22RE's Avatar
5 Year Member
http://web.archive.org/web/201102052.../6combinat.pdf
Old May 8, 2020 | 06:41 PM
DOWORK619's Avatar
Thanks, I’ll look at the parts locator link u sent me, hopefully I can figure it out, I’ve also replaced the oil pressure switch on it
Old May 8, 2020 | 07:44 PM
DOWORK619's Avatar
I unplugged the temperature gauge sender before I turned the key on and the gauge still reads hot. I have no clue how to figure this out.
Old May 9, 2020 | 02:40 AM
Paul22RE's Avatar
5 Year Member
Are you unplugging the correct sender? There are two temp senders, one for the ECU and one for the gauge. Gauge sender is located between cylinders 2 & 3 on the intake manifold for a 22RE, the ECU one is in the front of the intake..
If you did disconnect the correct sender, the next thing I would suspect is that sending wire grounding somewhere between the sender and the gauge. You have a multi-meter or a continuity tester?
Old May 9, 2020 | 04:59 AM
DOWORK619's Avatar
I used a continuity tester, and I’ll double check and make sure I unplugged the correct sender but I believe I did, thanks for ur help
22retank
Dec 11, 2020 04:53 PM
YotaSnap
Mar 24, 2014 05:45 AM
bipolarandproud
Oct 2, 2008 09:39 PM
