Temp Overshoot?
Old May 9, 2012 | 09:59 AM
linuxrunner's Avatar
Temp Overshoot?
As soon as i turn my key and start the engine my temp goes straight to the halfway point on the gauge even if it's first start in the morning.
I know that the non dual stage t-stat's are known to cause temp gauge overshoot but i thought that usually shows as overheating after a few min run time, this is instant and never past the half way mark.
Any ideas?
Old May 9, 2012 | 10:34 AM
snobdds's Avatar
It sounds like your sender is being grounded and causing the spike right off the bat. Check the wires for your temp sender and see if any of the insulation has rubbed off.
Old May 9, 2012 | 10:53 AM
BMcEL's Avatar
Could also be a bad sender or loose connection on the back of the gauge cluster.
Old May 9, 2012 | 01:49 PM
I will check the connector at the temp sender (the sender for the gauge is located around intake for cyl 3 correct?)
How does the temp sender work? if it's disconnected does the gauge show full cold? and if it's grounded does it show full hot?
coryc85
Dec 5, 2015 08:42 AM
bradahman
Oct 1, 2015 09:24 AM
Matthew Perez
Sep 28, 2015 05:43 PM
rmill05
Sep 27, 2015 01:43 PM
--Oz--
Sep 6, 2015 01:06 AM
