Tachometer
Old Sep 7, 2006 | 03:26 AM
MAXIMUS1968's Avatar
Tachometer
How do you hook up a dwell, tach meter to the 22re, can someone show or explain?
Thanks
Bryan
Old Sep 7, 2006 | 12:45 PM
rdlsz24's Avatar
You run your power and your ground, and you run the wire that measures the rpm's to the negative terminal on the coil.
Rob
Old Sep 7, 2006 | 07:22 PM
trythis's Avatar
dwell with Fuel injection, is that possible? I use my digital tach another way. I attach it to the (going from memory here, look it up in the FSM, don't go by what I type) TE- and battery +. It also depends on the tach you use.
Old Sep 8, 2006 | 02:43 AM
i geuss i will have to splice the negative wire from coil???...Correct? skin it for a connection?
Old Sep 8, 2006 | 07:37 PM
trythis's Avatar
not really, just remove the cap from the coild, and clip to the bare nut.
Old Sep 9, 2006 | 05:25 AM
JamesD's Avatar
The way I did it was to take the instrument cluster out and tap off the line for the tach. This way all the wires stay inside the cab.
James
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Tcsdef
Sep 7, 2015 11:17 PM
highonpottery
Aug 25, 2015 03:45 PM
Runner4Luke
Aug 12, 2015 06:42 AM
calderp
Jul 27, 2015 09:58 AM
