Is this symptoms of a bad TPS/AFM?
Old Feb 14, 2017 | 09:46 AM
84dreamyoda's Avatar
Is this symptoms of a bad TPS/AFM? (Video)
Here is a video of the problem I am having. If I try to hold my gas pedal around 2k RPM while in neutral and parked in the driveway this is what happens. I havent tried it in other gears yet, also I notice if I am driving and try to give it soem speed gas to get going their seems like a bogging down area but it clears up after a few seconds. Doesn't matter if warm or cold. I have done tps testing with ohm reader and it seems to be fine in those test. I followed http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml for the test. Could it still be bad, could it be the AFM ( I haven't checked it yet). I have deleted my EGR last year with block off plates and have most of my vacuum lines blocked off so I don't think its a vacuum issue but maybe I have the vacuum lines hooked up wrong?
edit* Forgot to mention that when I disconnect the TPS it does not do this anymore.
Old Feb 14, 2017 | 10:22 AM
Co_94_PU's Avatar
Looks like either a cutoff triggering or more likely a failure in the VAFM.
Test the VAFM resistance while manually manipulating the flapper.
Verify the TPS idle signal is reaching the computer.
Old Feb 14, 2017 | 07:16 PM
Punchy's Avatar
Use a analog ohm meter and ohm out the TPS and AFM, Look for dead spots as you slowly actuate them.
Old Feb 14, 2017 | 07:40 PM
Co_94_PU's Avatar
Vafm is a resistor ladder. It can have dead sections.
Tps, is a linear resistorIf you wear a dead spot in a tps you either loose vcc completely or the low range throttle angle (wiper rotates clockwise against the board)
Old Feb 14, 2017 | 08:03 PM
Crazy, I had my GF move the throttle slowly while I checked the TPS via VTA-E2 resistance and it seems pretty steady and didnt notice anything strange. I'll check the VAFM next and see what I get.
Old Feb 14, 2017 | 08:15 PM
Co_94_PU's Avatar
idle not throttle angle, if the CPU has an idle signal it will trigger a cut off above ~1200 RPM.
If you find good signal from the TPS and VAFM, check the Igf next.
Old Feb 14, 2017 | 09:55 PM
Terrys87's Avatar
I have had some bad AFMs that never thru a code but when doing a resistance check you could tell right away it was bad. I could also swap in a known good AFM and see the difference in how the truck run. The only time I ever got a code for the AFM is if I left the cable disconnected. Check to see if the flapper moves freely inside as well.
As far as the TPS, I could get them to pass test but in my opinion, they eventually just wear out. Sometimes cleaning the contacts can get some more life back into them but a truck with hundreds of thousands of miles, the TPS will have millions of cycles of operation on them and I think there is only so much you can do to get more life out of them. The TPS is on part that I will replace on an EFI motor if I suspect it is original and giving problems.
Old Feb 15, 2017 | 05:26 AM
Boostincx's Avatar
I literally just had the same problem, replaced TPS, fuel filter, cap ,rotor, plugs, wires... still no fix. I was throwing 2 codes both led to bad afm, I just didn't realize it cause my check engine bulb was burned out lol. Ordered a $65 used toyota AFM off ebay and bam problem fixed. Of course 3 miles down the road I get the dreaded code 52, it's always something.
