Swapping 22RE TPS
Old Apr 23, 2020 | 09:06 PM
Volnychev's Avatar
Swapping 22RE TPS
Can you run a late model ('89-'95) TPS on an early model (pre-'89) 22RE? Specifically would a late model TPS work with an early model ECU? I know that the early and late model TPS use different resistance settings for adjustment.
I'm swapping a '90-'95 (late model) intake plenum and throttle body onto my '86 22RE. I'd like to run my late model TPS since my late model TPS is Denso (OEM Toyota) unit and has a good plug connector. My early model TPS is a Beck Arnley and the plug connector is broken.
Old Apr 23, 2020 | 10:51 PM
Co_94_PU's Avatar
Yes, they are both zero to five volt outputs.
firewood bandit
Apr 16, 2016 06:45 AM
newTOyotas
Aug 12, 2012 12:39 AM
-=j0nnyr0773n=-
Nov 15, 2011 08:51 AM
thralldad
Aug 2, 2010 04:58 AM
joehill
Jan 25, 2009 10:04 AM
