Sugestions for mounting trans cooler on 94'
Old Jul 21, 2007 | 10:35 AM
scrid's Avatar
I was all pumped to see people adding trans coolers on the runners here, however after looking at my 94' it seems there are things blocking the only available space behind the grille on the drivers side. Anyone have any pics of mounting an add on cooler on a 90 - 95' runner with AC?
Thanks.
Old Jul 21, 2007 | 10:47 AM
4_runnin's Avatar
no pics .....how big is it
Old Jul 21, 2007 | 04:39 PM
ZUK's Avatar
ZUK
Thanks.
Room can be made....tranny coolers are most effective when mounted up against the front of the radiator. If you tie-rap it just behind the plastic grill (6 inches away from the radiator) then that is not the same as metal to metal contact with the radiator. The heat from the cooler will be pulled away most effectively with no gap to the radiator surface. I have a 01 Taco and I managed to make radiator contact with my medium large cooler. ONe of the best investments you can make with the auto tranny
Old Jul 21, 2007 | 05:23 PM
keithguts's Avatar
I Wish I Knew If I Had One . Don't Even No What It Looks Like, Or Where To Look For One. Any Pics?
Old Jul 21, 2007 | 05:46 PM
slosurfer's Avatar
Chickenlover's
https://www.yotatech.com/forums/f116...l-pics-115328/
Mine
https://www.yotatech.com/forums/f116...ll-pics-86774/
Make sure you use the search feature.
Old Jul 21, 2007 | 06:21 PM
leebee's Avatar
robinhood150 has a write-up on installing one behind the front skid plate, i put mine there as well. the po of my truck siliconed the grill in place, much appreciated.
lee
Pedalpwr27
Aug 13, 2015 06:37 AM
this_guy
Aug 10, 2015 10:44 AM
this_guy
Jul 31, 2015 01:27 PM
keithporter83
Jul 24, 2015 07:37 AM
Snort
Jul 9, 2015 03:58 PM
