stutter at 45 to 50 mph
Old Feb 22, 2011 | 07:16 AM
Adk_Yota's Avatar
93 3.0 SR5 4runner- developed stutter at 45mph but goes away a lil past 50 mph. TPS sensor maybe? Truck has about 1 year old NGK plugs and wires and newer cap and rotor
Old Feb 22, 2011 | 08:13 PM
BC-Luc's Avatar
Does the vibration/shake happen at that speed despite the gear your in, ie 4 or 5th etc...
Rear drive shaft U-Joints? Take off your drive shaft and feel how the u-joint move.
Luc
Old Feb 23, 2011 | 04:52 AM
Adk_Yota's Avatar
I'll look into the U-Joints...its its almost like the truck is trying to stall when it happens. Around 45mph while you are still accelerating there is usually 3 or 4 good bucks. till about 50mph. if you let off in the 45-50 mph range it stops, but as soon as you get back on the gas it starts again. i believe it happens in 4th or 5th
Old Feb 23, 2011 | 05:27 AM
BC-Luc's Avatar
Does the engine run up to higher RPM's in the lower gears?
Fuel filter, fuel pump/pressure/flow?
Here's a great link to help with your troubleshooting;
http://www.ncttora.com/fsm/1990-1995...es/repair.html
Good luck, Luc
Old Feb 23, 2011 | 05:54 AM
Adk_Yota's Avatar
Thanks Luc! great link for sure!
Old Feb 24, 2011 | 05:08 AM
Adk_Yota's Avatar
Well figured it out. Clutch is shot...after driving for hour and half last night it was starting to slip. Truck has a little over 130k and it is the stock clutch i believe.
Thanks again for the help!
Craig
pickle6415
Oct 19, 2015 08:08 AM
Flightguy
Oct 2, 2015 05:34 PM
kbpickens
Oct 2, 2015 03:37 PM
Shagool22
Sep 28, 2015 07:53 PM
accuracy
Sep 20, 2015 07:44 PM
