Still have strong fuel vapor smell 90 3VZE
Old Aug 16, 2009 | 09:43 AM
turborich's Avatar
OK, remember the last thread? I smelled a strong fuel vapor odor, The gas tank was pressurized & the gas cap o-ring was good. There was not any pressure when I removed the hose from the charcoal canister. The smell turned into a raw fuel smell & the pressure dampener started leaking because the screw had fell out. These are two separate issues or at least I'm pretty sure. So that's all fixed now but still on a hot 100 degree + day my fuel tank builds a lot of pressure & the vapor smell is there again until I release the fuel cap & the pressure.
So, Who knows what's going on here? Is it just too freakin hot or can something be done to fix this issue? Sometimes while walking through a hot parking lot I will smell the same fuel vapor smell with other cars as well. Not many though, maybe it's a common issue?
Thanks a lot as always, Rich.
Old Sep 6, 2009 | 03:18 PM
GerTTruj's Avatar
90 3VZE - Raw Fuel Smell / Odor
I'm currently dealing with what I think is a leak under the plenum (air intake chamber). I have to crank engine about 10-15 seconds until it starts, due to loss of fuel pressure.
Once engine is started, driven a few miles and then parked, I can hear the dripping fuel onto the warm block as it steams away "psst psst psst..."
I'm not savy enough to remove the plenum myself nor do I have the time.. so I'll have to take it in to my trusty mechanic.
Years ago I had a fuel rail regulator that had a slight leak which would close when hot and gradually leak as it cooled down. I think this may be the same problem I have now.
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
tomczaksdiesel
Jul 26, 2015 10:35 PM
smiley52
Jul 11, 2015 05:16 AM
