starting to pull the clutch, wish me luck.
I did this by myself using a jackstand on each the driver and passenger floorpans, a 4x4 (board not truck
) across the stands and a ratchet strap looped over the 4x4 and around the tranny through the shifter hole. worked well, quite stable and I was able to adjust the tranny height via the ratchet from underneath the truck. Super method for the reinstallation, helpful for the take out. Not my idea BTW, saw it in a pic somewhere, maybe here.
I have two inches of body lift and was able to get to the two top tranny bolts using extensions long enough to reach the shift hole. I was able to remove them with an impact from the cab this way, way more comfortable than from the engine bay and way faster, but may not be possible without the BL.
If you don't have it all back together, go ahead and replace the rear main seal while the tranny is off, cheap part might as well do it now.
Mike
) across the stands and a ratchet strap looped over the 4x4 and around the tranny through the shifter hole. worked well, quite stable and I was able to adjust the tranny height via the ratchet from underneath the truck. Super method for the reinstallation, helpful for the take out. Not my idea BTW, saw it in a pic somewhere, maybe here.I have two inches of body lift and was able to get to the two top tranny bolts using extensions long enough to reach the shift hole. I was able to remove them with an impact from the cab this way, way more comfortable than from the engine bay and way faster, but may not be possible without the BL.
Mike
on my '86 22r..i can get the passenger side top tranny bolt from up top..with one of them ratcheting wrenches...the driver side is not so easy..i too have bought about 6ft worth of extensions for tranny stuff..haha
#26
#27
you know, I thought I'd done some strange, and dangerous things before, but I don't think you could get me to climb underneath a transmission knowing it's dangling from the interior grab handles
that just... just doesn't seem right...
#32
HAHAHAHAHAHA. I'm sure that quote will be in signatures pretty soon.
#35
It's finished.
Robb I missed your phone call this morning about the tranny jack but had already rented one for 30$ through Monday. Sorry about that. I do still need to hook up with you on that steering wheel and soft top.
I don't know what that noise was that drove me to do this in the first place but it's gone now. The clutch and pressure plate that came out were in pretty good shape although all the metal was rust pitted like crazy. The throw out bearing was really really loose internally and the pilot bearing was just a mess.
With the little bit of shifting I did in the garage it feels a hell of a lot better, doesn't make any noises and I no longer have to fight to get the rig into gear. I'll be doing a test wheeling trip tomorrow to make sure everything works. Next week my new bushings from Marlin Crawler will be here and that should help clean up the rest of the shifter slop. Oh and while I was under there I removed that silly sway-bar and tossed it.
I had hoped to get to the IACV this weekend but this clutch job has worn me out. I'm going to drink a beer and relax for a little while.
#37
#38
lmao, jk man
I'm going to install a multi-friction clutch when I remove my motor and do a rebuild, and you can bet there will be pictures of it
but that's just the way I am
