started but died, now wont start back up
Old Dec 14, 2009 | 04:01 PM
stephencox's Avatar
ok, 93 v6 3.0 auto 4runner.
went out and started it up to warm it up(it was cold out, in the 10's and 20's), went inside, came back out and it had died, smelled funny in the cabin like something burned, wouldnt start back up ever since. turns over, and sometimes sounds like its about to, but just wont.
-changed the plugs.
-checked the distributer cap and rotor, working fine.
-connected terminals b+ and F sumthin or other and heard the fuel pump.
-took the fuel hose off right after the filter and leaked quite a bit so im assuming its getting fuel.
also, theres a tapping noise coming from the air filter. opened it up and it looks like its just the metal flap but i dont remember hearing that before when the truck ran.
any advice? a checklist maybe?
Old Dec 14, 2009 | 05:41 PM
Catamount's Avatar
There's an oxygen sensor by the air filter canister or in the throttle throat. Won't run if its bad, fouled or air duct between them is open. just a hunch.
Old Dec 15, 2009 | 10:36 AM
stephencox's Avatar
thanks for the tip, but unfortunately i popped off the cover for the timing belt cause i was told to look at that too and it turns out the belt is stripped
Old Jan 19, 2012 | 01:22 AM
19864runnerHawaii's Avatar
yup those timing belts go
91toybeater
Dec 27, 2015 07:46 PM
puffin04
Jul 10, 2015 09:17 PM
MadMax48
Jul 3, 2015 08:26 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
slider417
Jun 22, 2015 10:18 AM
