SR5 Gauges Work in 22R (carbureted)?
Old Dec 11, 2012 | 06:02 PM
Kevin1988's Avatar
Question SR5 Gauges Work in 22R (carbureted)?
Hi all, today i found a 1987 SR5 Cluster for my 1987 Toyota Pickup (22R Carbureted) and i was wondering if it will work for a carbureted engine? i know all of you say that the cluster would always work in a 22RE but will it work in a 22R?
Kevin
Old Dec 11, 2012 | 06:53 PM
dakotawho's Avatar
There's one in my 22r, i know it was swapped in, oil pressure gauge is a little slow but works fine in my truck, besides gas gauge being stuck lol
Old Dec 11, 2012 | 07:42 PM
TrikeKid's Avatar
It's a plug and play swap aside from the fact you need to swap the oil pressure switch you have now to the actual sending unit used in the SR5 trucks.
Old Dec 11, 2012 | 07:52 PM
stock87's Avatar
I have one in my 87 22R and it works fine. I just had to change out the oil pressure sender from the dummy light switch to the actual pressure sensor, and run a wire from the coil to the tach. Everything else 100% plug and play.
Old Dec 12, 2012 | 08:18 PM
slow-mo's Avatar
Just adding that I have done the swap as well.
I do believe, from reading here on Yotatech, that you will need the instrument cluster from the 22R-E and not the V-6 vehicle (4Runner).
marcusSRG
Jun 27, 2015 07:13 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
Eagle564
Jun 23, 2015 11:29 PM
gog1968
Jun 22, 2015 05:55 AM
