Sounds like a diesel!!
Old Mar 4, 2007 | 11:10 PM
fork's Avatar
toyota wants to charge me 800 to adjust my 3vze valves. ill deal with the ticking sounds instead
Old Mar 5, 2007 | 02:27 AM
ShortyzKustomz's Avatar
Originally Posted by TOYZILLA
I'm surprised no one said any thing about with that many miles on it .that the timeing chain might be rubbing on the cover alittle.Yes these motors do make some noise, but if it's really loud it is either the chain on the cover or exuast leak or cam wear noise. which would be do from wear.time for a rebuild soon.
Like I said in my original post, This motor is supposed to be a replacement, not sure if it was new or reman. But either way its only supposed to have 46,000 on it
Old Mar 5, 2007 | 03:17 AM
rubysRunner's Avatar
Mine sounds like that too. My dad is constantly bugging me about how it sounds like diesel (he's a domestic guy, so anything he can do to talk down about an import..you know the type..don't worry I'm trying to convert him). My truck had a reman put in it before I bought it, and has about 40,000 miles on it now. It's been noisy since the day I bought it, it worried me for a while. I had a valve adjustment done last year, and I believe it's about as quiet as it'll ever be now...which is pretty damn noisy. I don't worry about it anymore cuz she runs like a top.
Old Mar 5, 2007 | 02:43 PM
TOYZILLA's Avatar
motor noise
OK SORRY MISSED THAT Anyway the lifters may need adjusting/shims an could be the timeing chain tensioner has broke or losen an the chain is rubbing the chain cover sorry on spelling. i missed school that day
Old Mar 5, 2007 | 03:53 PM
  #25
84sr5yoty's Avatar
Like I said in my original post, this motor is supposed to be a replacement, not sure if it was new or reman. But either way its only supposed to have 46,000 on it
Rebuild is a very loose term. Some people think that replacing all of the gaskets is considered a full engine rebuild, so don't assume anything. There are several causes for ticking besides a valve adjustment.
1) Worn valve adjusting screws that cause the valve clearances to change with each movement. It will be impossible to correctly set the valve clearance under these conditions.
2) Worn out spacer between #2 & 3, causing a misalignment in geometry.
3) Worn rocker arm pads. Most of the time you can have them machined, but you risk damaging the head gasket when removing the rocker arm shafts.
Also, it's well known that the stock spec is a little on the loose side for the rocker arm adjustment. I've heard of people using adjustments as tight as .006/.009 with a hot engine. I set mine at .007 .011 with the engine COLD.
By the way, my 84 is dead silent with no valve noise what-so-ever. Yes, it's possible!!
http://www.wheelingadventures.com/Tech/Fixs.htm
Old Mar 5, 2007 | 05:10 PM
  #26
Well my receipt that came with the folder of paperworks and hundreds of receipts shows a replacment motor was dropped in at 200,000. It wasnt done at a dealership so I dont know anything about the motor put in other then it was def a little pricey for it to be a junkyard motor. My exhuast leak is def getting worse, I just havent found the exact leak yet. Hopefully I can get it fixed and see how bad this tick really is
Old Mar 5, 2007 | 05:31 PM
  #27
brendonv's Avatar
Can you expound on that spacer? What were your symptoms before you installed them, and what was the outcome?
Thanks
Old Mar 15, 2007 | 10:42 PM
  #28
84sr5yoty's Avatar
Thanks
I only had to replace the adjuster studs, not the spacers.
Speaking of spacers, in 1987 Toyota recalled my truck for the spacers and they were replaced at that time. I don't know what material they're made out of but they're bronze in color. They still look fine after all of these years and miles. For some odd reason it seems that only a small handful of people ever got that memo though.
Old Mar 15, 2007 | 11:10 PM
  #29
86toysr5's Avatar
my 20r is pretty quite xcept my exhuast
Old Mar 21, 2010 | 09:54 AM
  #30
juheRoaryota's Avatar
Did the dealership use the original manifold? If so i was told they come off warped and do not seat right when put back on.
Old Mar 21, 2010 | 04:39 PM
  #31
Flash319's Avatar
Timing chain tensioner.
Old Mar 21, 2010 | 07:29 PM
  #32
Wow, this was one of my first posts on this site.... 3 YEARS AGO, Seriously why did any of you post?
As far as the question asked... No the dealership did not use the manidold cause I said pretty specific that a dealership didnt install the motor in that truck. Installed plenty of manifolds on Yotas without leaks... ::Shakes Head:: But that was 5 vehicles ago
Old Mar 22, 2010 | 05:50 AM
  #33
Flash319's Avatar
haha someone brought it back to life....
Old Mar 22, 2010 | 06:07 AM
  #34
It ended up just needing a valve job from hell... Now my current Yota on the other had had the timing chain fun... As the common driver side guide breaking happened. Its got all metal guides now
Old Jun 23, 2010 | 12:59 PM
  #35
MIKE_1991_MILLER's Avatar
back when i bought my Toyota it sounded like a desil, the previous owner had to change the timing chain cover and timing chain and that dident change eneything, since it had 245,000+ miles on it i fully rebuilt it had the crank polished, block checked, rods checked, put all new gaskets, new pistons, oil pump, water pump, bearings.and after that the noise ended up being that my crank bearings were toast and it dident have oil pressure so idk if you if u have a dummy light or a wet gauge that u could elminate that as i possibility but saying it sounded like a desil is exlactley what i had. and now it hasent sounded like that at all. so idk
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
an1mal_69
Sep 8, 2015 09:40 AM
seab1209
Sep 3, 2015 05:41 PM
