Something's Wrong, please help
Old Sep 20, 2008 | 01:23 PM
keithguts's Avatar
ok, I have a 1995 4runner 3.0. I did a compleat tuneup and the dam thing still has hesitation on take off. I was told the the # 6 injector was not firing, so I had it replaced along with the rest of the injectors. Yes all new injectors, and still doing the same thing. It runs great once it is passed the little hesitation. Also changed the fuel filter as well.
New plugs, wires, air filter gass filter pcv valve, new cap, and rotor. All parts are OEM right from toyota.
Please give me your feedback on my problem.
Old Sep 20, 2008 | 02:08 PM
jason191918's Avatar
I had the same problem and did the same repairs at one point, with no success. Then I heard it could be the EGR, so I removed it. been problem free since. If you need to pass emissions, this is not a solution for you (assuming it is even the problem). You could probably temporarily block it off and see what it does for you.
Old Sep 20, 2008 | 02:38 PM
keithguts's Avatar
how do you block this off? can you explain to me. thanks
Old Sep 20, 2008 | 02:45 PM
mr toytech's Avatar
could also be a bad tps.[throttle position sensor].
Old Sep 20, 2008 | 03:19 PM
This would be easier to test. Just unplug it. If it runs better w/ it unplugged, the TPS is toast. Try this first.
Old Sep 20, 2008 | 03:24 PM
https://www.yotatech.com/forums/f116...05/index5.html
page 5, post 114
Instead of removing it like i did, you can just plug the tubes for the EGR.
Steven.m.paulk
Jun 7, 2020 10:45 AM
zytra
Jan 24, 2019 03:16 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
charlie_fong
Sep 27, 2015 10:06 PM
