Someone who knows 22re's well. HELP!!
Old Feb 11, 2009 | 02:58 PM
abecedarian's Avatar
IF the 51 is caused by the TPS, as it likely is, it is because the ECU is not getting the IDL signal (meaning the TPS is not fully closing or the contacts within are bad) when it thinks you should: i.e. when you let off the throttle and the engine rpm's drop low enough to be at idle but the TPS is not saying the throttle's closed. What I suggested above should get the TPS into that operational range, unless the TPS IDL contacts are bad.
Old Feb 11, 2009 | 03:01 PM
edit to add (sorry, didn't want to hijack my own post)...
I figured what I wrote out once when I replaced the TPS on my 88 and couldn't hold the meter probes on the TPS well enough without removing the throttle body. Since I was not in a position to purchase what I'd need to make a new TB gasket, I figured why not let the ECU tell me (by way of the engine idle) that the TPS was registering throttle closed.
Old Feb 13, 2009 | 11:34 AM
ohyeahcrx's Avatar
Onother issue that has seemed to come up.
Chocolate milk oil.....as far as I know that means one of two things. Either a blown head gasket (which it isnt because my compression is fine.) or the timing chain has worn a hole in the cover, But seeing as I just replaced that whole thing thats not it either.
So my question is, is there something else that could be causing chocolate milk oil? Or could it be some leftover chocolate milk that was in the oil pan from before I replaced the timing cover? So in a way do I need to flush the oil system with oil to get rid of all the chocolate milk?
Any ideas?
Old Feb 13, 2009 | 11:59 AM
muddpigg's Avatar
Contaminated oil is not good. Coolant (if that is what your using) can cause other problems down the road.
Old Feb 13, 2009 | 12:02 PM
  #25
Coolant / water in the oil will deteriorate the main and rod bearings in quick order. It needs flushed as quickly as possible.
Old Feb 13, 2009 | 12:05 PM
  #26
ohyeahcrx's Avatar
How do I flush it? just keep running oil through it?
Old Feb 14, 2009 | 12:50 PM
  #27
ohyeahcrx's Avatar
Any ideas?
Old Feb 15, 2009 | 09:37 AM
  #28
ohyeahcrx's Avatar
So I changed the timing cover, chain, and all that thinking that that was the reason I had water in my oil. Finnished that and nope still have water in my oil. What else can it be? And its not the headgasket cause the compression is fine. What else causes water in the oil. Lay it on me. Every possible thing.
Thanks..
Old Feb 15, 2009 | 11:16 AM
  #29
934rnr's Avatar
The head gasket maybe still leaking or possibly a cracked head just because you have good compression doesn't mean it's not leaking somewhere.
The only other way to check it is to a pressure check of the cooling system. That will only determine you have a leak. You have to find it from there.
Also water can still be hanging out at the bottom of your oil pan when you drain it you still don't get everything out of it there is still at least 1/8 qt of fluid at the bottom of the pan.
Is it water or is it radiator fluid?
After you changed the oil is the oil/water ratio(chocolate milk) any better or is it the same?
Old Feb 15, 2009 | 01:30 PM
  #30
ohyeahcrx's Avatar
And how would I do a compression check on my cooling system?
Yeah thats what i was thinking. But its def water cause it has made a nice milkshake in my engine :/
Old Feb 15, 2009 | 01:32 PM
  #31
muddpigg's Avatar
Compression test your rad.
Old Feb 15, 2009 | 03:49 PM
  #32
934rnr's Avatar
It's a cooling system pressure tester nothing fancy.
Old Feb 15, 2009 | 06:50 PM
  #33
muddpigg's Avatar
Yep what he said, still try it rule out if HG fixed leak and simply not getting all the fluid out of crank case.
Could be something else besides HG
Old Feb 15, 2009 | 07:17 PM
  #34
vital22re's Avatar
totally a bro
does it have an oil cooler? could be a faulty oil cooler .... if you have one... not sure. And just because your compresion is fine doesn't mean your head gasket is okay. There are several ways a headgasket leaks. Oil to cylinders, water to cylinders, water to oil. Good luck in figuring this out.
Old Feb 16, 2009 | 05:51 PM
  #35
ohyeahcrx's Avatar
So I can just get a cooling system pressure tester at any auto parts store? ha cause ive never heard of it
Old Feb 17, 2009 | 05:28 AM
  #36
934rnr's Avatar
One made by Slant
http://www.sjdiscounttools.com/sta12270.html
Or a Craftsman just run down to sears.
http://www.sears.com/shc/s/p_10153_1...id=00946342000
Old Nov 1, 2010 | 02:57 PM
  #37
rogerman's Avatar
Sorry for thread reviving but did you ever solve the problems?
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
Iceman4193
Aug 28, 2015 08:43 PM
PlayAwhile
Jul 20, 2015 11:36 AM
