So I'm guessing my rear axle oil seals are toast?
Old Mar 31, 2010 | 09:18 PM
fender250's Avatar
I bought another yota recently. A 93 4wd 22re with a 2"body/3" suspension lift. 5.29 gearing, on 35's...but it needs some TLC.
The brakes were flaky when I bought it, so I started with the front. I installed new rotors and pads, and it helped a lot, but didn't completely solve the problem. I figured I'd to the rear as well once I got the time to do it...tough to find time with a 2 month old in the house.
Anyway...this is what I found when I took the drum off.
I am guessing the axle oil seals are gone? Anyone else come across this? I searched and found descriptions of this problem, but no pics. Just want to confirm before I start ripping everything apart.
Also, anyone have any tips on how to get a stubborn drum off? The other side is being a bitch. The 2 boltholes on the face of the drum used to pop it off are completely stripped. I've tried to loosen off the adjusting bolt but there is no room back there with my big mitts to get 2 screwdrivers in that tiny hole.
Old Mar 31, 2010 | 09:23 PM
waskillywabbit's Avatar
Yep you guessed right. Nice write up on 4x4wire how to service the rear axle.
http://www.4x4wire.com/toyota/mainte...axle/oil_seal/
Old Mar 31, 2010 | 10:13 PM
whutface's Avatar
I just replaced those seals myself. To get to the outer seal your gonna have to remove the bearing I'm pretty sure, I cant remember cause I was replacing the bearing anyway. But if your removing the bearing your gonna need a press.
Road Bull
Oct 10, 2015 04:55 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
ItsJustD
Jul 7, 2015 07:49 AM
toyoda8488
Jul 5, 2015 10:18 PM
HRDC0R19
Jul 5, 2015 06:43 PM
