Slotted roters worth the money?
Old Oct 3, 2009 | 09:53 PM
idanity's Avatar
BREMBO anyone....??
u might want to read (or re-read) my 1st post about QUALITY....
Old Oct 3, 2009 | 10:38 PM
FredTJ's Avatar
Originally Posted by idanity
BREMBO anyone....??
And, as I said, quality ones probably won't experience stress cracks, however they still won't improve stopping ability at all. They will decrease it, everything else being the same. Less surface area and less mass = less stopping ability.
Fred
Old Oct 4, 2009 | 12:10 AM
stormin94's Avatar
If you want increased stopping power, go with larger diameter rotors, rather than the slotted rotors.
To answer the thread title's question of 'are slotted rotors worth the money', NO. They certainly are not. While you may notice a slight advantage in heat dissapation over stock brakes of the same size, you will not be able to stop larger tires any easier, or save any money with the drilled/slotted rotors.
My suggestion is to upgrade your front rotors to a larger diameter, as well as the rim size to accomidate the larger rotors. Since 80% of your braking power is in your front wheels, upgrade the front before you upgrade the rear. Unfortunately, my 4Runner came from the factory with rear ABS, which is pretty much pointless, unless I feel the need to fry the clutch and power brake it.
Bottom line: I'd upgrade the front rotors to a larger diameter for increased stopping power, and NOT get slotted rotors.
Old Oct 4, 2009 | 05:43 AM
FredTJ's Avatar
And who makes a conversion kit to larger diameter rotors for that vehicle ?
Fred
Old Oct 4, 2009 | 06:48 AM
  #25
22RUCRAZY's Avatar
Depends on what you do with your rig . If you see alot of competion type events then yah if its your daily driver that sees the trail once a month or less then no imo
Old Oct 4, 2009 | 11:57 AM
  #26
stormin94's Avatar
Fred
I'm not too sure about that for these Toyotas. But you could definitely do it yourself, although it wouldn't be as easy as a kit.
It's fairly safe to assume that you could fine lots of info on that here on YT though.
Old Oct 4, 2009 | 12:41 PM
  #27
FredTJ's Avatar
I'm not looking to do it.
It's not a trivial job by any means. You can't just slap larger diameter rotors on. You would have to make a bracket to move the calipers up further and that would have to be a really beefy bracket. There is a lot of force there.
Fred
Old Oct 4, 2009 | 01:09 PM
  #28
idanity's Avatar
it may be easier to get a deployable parachute...
Old Oct 4, 2009 | 01:23 PM
  #29
90-3vzeslug's Avatar
I have to say that I upgraded the front rotors on my mustang to slotted rotors and absolutely love them! Make sure to buy a good name brand, cheap out and they are no better than stock. If swapping always go with a better pad (I use ebc, and they are amazing!) the combination of the better rotors and pads will certainly make a big difference. Also I have seen the ebc pads last far longer than stock on the mustang. as with almost all front engine vehicles about 80% of braking is done by the front brakes, so that'd be where i'd upgrade first.
clok
Nov 19, 2015 01:09 PM
IntoTheVoid
Oct 24, 2015 04:54 PM
taraf
Sep 25, 2015 02:57 PM
sonorn67
Sep 19, 2015 05:39 PM
