Should my engine run this hot? [picture]
Subscribe
Oct 13, 2014 | 01:59 PM
I was wondering if my engine should run this hot after driving for about ten minutes. After replacing the radiator and thermostat . I put in a durlast thermostat.
Reply 0
Oct 13, 2014 | 02:08 PM
Not too hot......... if the gauge is accurate.
These gauges were never too accurate, and now they are 20+ years old.
Get and use an IR temp gun, and see what is really going on.
Peace of mind is a wonderful thing.
Reply 0
Use a thermometer to check the temp of the upper rad hose and top of the radiator.
Stock gauges are not the most accurate.
Reply 0
Oct 13, 2014 | 02:18 PM
Ok . One thing is after driving for 10 minutes I can't lay my hand radiator or engine. Is that normal?
Reply 0
Oct 13, 2014 | 02:29 PM
With a thermostat installed, coolant enters the top of the radiator @ 180'f+.
This is too hot to lay your hand on for more than the shortest touch.
Generally speaking, if the cooling system is full of liquid, and the coolant does'nt boil over, the engine is not dangerously hot.
Reply 0
Oct 13, 2014 | 02:34 PM
Meant to say one other thing. Coolant reservoir was empty the other day. Is that bad or good?
Reply 0
Oct 13, 2014 | 03:24 PM
After you drain and refill the system it will sometimes empty the reservoir as it slowly purgues out bubbles. I would suggest checking and filling it to the "full" line when cold for at least 3 heat cycles. If it keeps pulling a lot out of the reservoir after a few heat cycles then you have a leak somewhere.
Reply 0
Oct 13, 2014 | 05:06 PM
if your heat working? might be a simple air pocket. those cheap thermostats never have a bleeder nipple in them so i drill a real small hole in them to help with air pockets.
Reply 0
Oct 13, 2014 | 05:48 PM
+1 for using more accurate temp gauge & monitoring reservoir level.
Gage alone while driving is not a good indicator. The weekend my head gasket blew, I was driving in 3-digit temps in San Bernardino County and noticed my gage reading lower than normal. I thought that maybe because I was at freeway speed. Alas! The night we drove out of the trail head, she overheated, and I found out HG had blown. Theory behind the low gauge reading is because of blown HG, coolant was overflowing while I was driving so when I stopped, there was no clue on the ground. Coolant level had gone so low so it was not touching the temp sender anymore.
I'm considering installing one that actually reads numbers (°F), with temp sender installed lower on the engine block so it would always read coolant level even when level goes low. potential location for temp sender is port just below and to right of freeze plug on right on this Photo Courtesy of Chefyota4x4.
+1 for oldblue ... talking about the jiggle valve
Reply 0
Oct 13, 2014 | 06:11 PM
Quote: I was wondering if my engine should run this hot after driving for about ten minutes. After replacing the radiator and thermostat . I put in a durlast thermostat.
Looks to me like it's right dead center in the middle of the range, where it's supposed to be. Mine gets to that point in about 5 minutes and then stays there for the rest of whatever trip I'm taking. That's the mark of a well regulated system.
As was said, if you're not boiling water out, the engine isn't running so hot as to damage it. Keep in mind that too cold isn't a good thing, either. It results in poor fuel vaporization and less than optimal lubrication.
Unless you're continuing to lose coolant, I see nothing to worry about.
Reply 0
Oct 13, 2014 | 07:39 PM
That is exactly where my normal reading is, about 1 needle width above horizontal. If you continue to lose coolant you better figure out where it's going.
Reply 0
Oct 14, 2014 | 04:57 AM
My papaw said something about coolant going out the exhaust or a bad thermostat.
Reply 0
Oct 14, 2014 | 05:33 AM
That truck ain't up on CL is it?
Reply 0
Oct 14, 2014 | 06:43 AM
If you mean craigslist yeah . I think I'm going to take the truck to my grandparents house some time this week to fix the oil gasket. I think my oil is is making my engine run to hot. Due to not change it because of the oil gasket . I read in the manual that in proper grade can make over heat. Is that true or not?
Reply 0
Oct 14, 2014 | 06:56 AM
Oil making the engine over heat? That's a new one…
Reply 0
Oct 14, 2014 | 09:47 AM
With engine cold, and radiator cap off, watch if coolant is splashing/bubbling in radiator really badly, not just from vibration. That would indicate bad HG.
Also, with radiator cap known to be absolutely good, there should be no bubbling of coolant into the reservoir.
Quote: over heat. Is that true or not?
Myth.
Quote: Oil making the engine over heat? That's a new one…
Maybe if it's Extremely IMProper grade, like using 80W-90 gear oil in engine - LOL!
Reply 0
Oct 14, 2014 | 11:42 AM
There were a few bubbles for like 30 seconds then stop.
Reply 0
Oct 14, 2014 | 12:51 PM
You can also stretch a balloon over the fill neck, and if it inflates, you have a problem
Reply 0
Oct 14, 2014 | 06:49 PM
Quote: You can also stretch a balloon over the fill neck, and if it inflates, you have a problem
Hmm, never heard of that one. Sounds like it might work though.
Reply 0
Oct 15, 2014 | 11:48 AM
I try the balloon idea.
Reply 0
