setting 3vze distributor
Old Dec 28, 2012 | 09:56 PM
NorthIdahoyota's Avatar
When tearing down the engine I forgot to mark the rotor position, so I set the crank to zero and the rotor on the #1 point, and now when I try to start it it only pops and backfires. Does anyone know the correct place to set the rotor too?
Old Dec 28, 2012 | 11:07 PM
brianh699's Avatar
You may have been off 360 degrees try rotating engine and reinstall distrubutor.
Old Dec 29, 2012 | 05:29 AM
MudHippy's Avatar
What he means is you have the distributor installed 180° off. So you'll need to remove the distributor, rotate the crank 360°, then reinstall it. So that the rotor is pointing at the #1 point when the #1 cylinder is at TDC of the compression stroke, instead of at TDC of the exhaust stroke.
Old Dec 29, 2012 | 11:37 AM
thanks, that was exactlly my problem, flipped it 180 and it fired right up
nonstop
7
Aug 11, 2015 09:26 AM
Flossy
Aug 5, 2015 05:14 PM
smiley52
Jul 11, 2015 05:16 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
