Sensor on top of water outlet
Old Feb 19, 2022 | 09:17 AM
Danson's Avatar
Hey all,
Was hoping someone could definitively tell me what this sensor actually does. I have seen it referred to as a temp gauge sender, a coolant temp sensor for the ECU, an air conditioning temperature switch (shuts off the AC if too hot?), a 4WD related temp sensor... some trucks have it, some don't, some look like mine, some don't. Which is it? Also, my single wire for it didn't have a connector when I got the truck, so I don't know what the stock connector looks like but I assume it's one of the round off-white plastic OEM connectors. Guessing I can't get a replacement, though?
Here's what it looks like. Opening is too small for a spade to fit inside, prong inside is also too small for a spade anyway. P.O. somehow soldered the wire directly to the post but that of course broke. I found an old female barrel connector and put that on the wire, then squished it until it was roughly spade-shaped. Fits on nice and tight but obviously doesn't seal the connector.
Jameshpulse
Dec 22, 2014 02:35 PM
89whitetoyota
Aug 1, 2013 10:33 AM
rawfeels
Jul 22, 2011 11:23 PM
yota81
Jun 8, 2009 10:32 PM
Guardian_Saint
Feb 7, 2007 07:29 AM
