searched and searched but issue remains.
Old Jan 1, 2014 | 07:25 AM
combatcarl's Avatar
I have a squeak, too. Seems like it's related to my unbalanced tire going around. It's my R/R spring bushings/shackle. Does it squeak when ya rock the truck?
Old Jan 1, 2014 | 07:32 AM
kawasakilewis's Avatar
may sound stupid but grease your speedometer cable, they will squeak and sound HORRIBLE and it will sound like its coming from all kinds of places.
Old Jan 1, 2014 | 09:50 AM
KaptainKoolz's Avatar
1.) my 4runner does not have a center section on the rear driveline
2.) just tried rocking the truck about with my body weight and no sounds whatsoever
3.) How would I go about lubing the speedo cable?
Old Jan 1, 2014 | 10:03 AM
unplug it off the back of the speedometer(you can reach up between the gas and brake pedal and unplug it) unthread the fitting off the transfer case and you can pull the cable out of the housing, get some grease in your hand and lightly coat the whole thing in grease and reinsert it.
Old Jan 1, 2014 | 10:44 AM
  #25
normal or not? my money is on the latter
Old Jan 1, 2014 | 10:49 AM
  #26
BigBluePile's Avatar
Geezus. That's bad, eh. Fortunely, that's a really simple job you can do yourself. Hardest part is getting access to a press.
Old Jan 1, 2014 | 10:53 AM
  #27
RJR's Avatar
RJR
Definitely doesn't look normal. It's a little hard to see from your picture what's moving in relation to what, but nothing on the front wheel should be that loose.
Old Jan 1, 2014 | 10:57 AM
  #28
Thanks for the help gents, the entire rear axle was rebuilt in june to the sum of over 2k, obviously i was taken to school and someone only replaced the passenger seal and bearing.
Old Jan 1, 2014 | 11:11 AM
  #29
JohnnyCanuck's Avatar
should be no play at all on those rear axles. The good news is you found the source of your squeak, and it's easy to replace.
Old Jan 1, 2014 | 11:13 AM
  #30
Yes I will look into replacement once I get my cash back for work that was supposedly done
Old Jan 1, 2014 | 11:41 AM
  #31
Don't be scared to get dealership parts either. Bearing, seal(inner/outer), retainer and clip. Two sets.
Old Jan 2, 2014 | 05:33 PM
  #32
all4runners's Avatar
Glad you found the problem,
Old Jan 3, 2014 | 01:15 PM
  #33
I took it back to the shop that rebuilt the rear axle last summer, they said the driver side half shaft spun the bearing and it grooved the shaft somehow which is what caused the play, they are going to replace the shaft and bearing/seal. Hopefully I wont have anymore problems, I am hoping to sell this truck soon
Old Jan 3, 2014 | 02:05 PM
  #34
You are selling it? GET OUT! J\k, glad the shop is honoring their work, glws.
Old Jan 3, 2014 | 02:10 PM
  #35
If everything goes to plan i may be snagging an 06 4runner as a replacement
Old Jan 3, 2014 | 02:22 PM
  #36
combatcarl's Avatar
It's got a 3vze, I don't blame ya. 3.4 swap is cheaper than a new rig, though.
Old Jan 3, 2014 | 02:33 PM
  #37
Yea im quite convinced that the 3vze is a pile, it would be a tad better with a manual trans but the 3vze-auto combo sucks. The 06 would be an "in family" trade of sorts, its high miles (150k+) but I have done all maintenance on it since 50K or so miles. I would only have to surrender my 2nd gen.
Old Jan 3, 2014 | 02:44 PM
  #38
combatcarl's Avatar
Well, that ain't a bad deal then. Don't go far, now.
MO transplant
Apr 23, 2023 11:58 AM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
smiley52
Jul 11, 2015 05:16 AM
