Scuba's Manual Hub Rebuild
Old Oct 26, 2008 | 04:17 PM
scuba's Avatar
you read my mind wabb, I hope you know that was me that emailed you about the follower pawl.
Anyway, Yes this not going back in deal is with face and dial and clutch assembled in my hand, should i try putting it in the hub ?
Old Oct 26, 2008 | 04:24 PM
scuba's Avatar
BALLER!!!
Get it going, inserted it into the hub body and it locks and unlocks properly.
Locked the splines will not move, Free they do.
Safe to say ive go it ?
Old Oct 26, 2008 | 04:27 PM
abecedarian's Avatar
looks like I'll be hitting the wrecking yards tomorrow sometimes. I'll see what I can come up with.
Old Oct 26, 2008 | 04:32 PM
waskillywabbit's Avatar
It won't work in your hand...that is the problem...I mean it will but not sure how to explain it to you to test it.
Old Oct 26, 2008 | 04:36 PM
  #25
scuba's Avatar
well all is good, bout to grease it up and get it in there
Old Oct 26, 2008 | 04:39 PM
  #26
flashkl's Avatar
Heh, I am actually having the same problem with my hub not wanting to unlock... and also my follower pawl is mangled as well...
The flat side of the big spring goes against the pawl, not the dial.
What does that mean? Doesn't the big spring go in between the pawl and the dial?
  #27
Light grease, just enough to coat the parts lightly. Too much grease and it sticks...took apart some the other day...and the pawl would not move cause of so much grease.
Old Oct 26, 2008 | 04:40 PM
  #28
Take the big spring out and set it on a flat surface. One side is flat and the spring will sit vertical. The other end is not flat and the spring will sit like the leaning tower of Pisa.
Flat end goes next to the pawl, not the dial.
Old Oct 26, 2008 | 04:42 PM
  #29
flashkl's Avatar
ahh, I get it... what happens if you put the spring in backwards? Could that be what's keeping my hub from unlocking?
Old Oct 26, 2008 | 04:43 PM
  #30
Your truck will implode.
Yes, if you put the big spring in upside down the hub won't work properly.
Old Oct 26, 2008 | 04:47 PM
  #31
flashkl's Avatar
Hmm, better fix that spring soon then. I once had a civic implode on me after I put spinners on it, wasn't pretty...
Old Oct 26, 2008 | 05:52 PM
  #32
iamsuperbleeder's Avatar
I didn't realize there was a correct and incorrect orientaion (spelling) to that big spring??? Mine work properly after my rebuild, so I assume all is well...
And oh yeah, untill you place the hub cover and dial on the body, it's no going to move to it's proper locking and unlocking positions; the hub body keeps everything in line and on track... it's hard to explain really, but once you bolt it together things move like they should... assuming it's put together right...
I do have a question though...
Does anyone know where you can purchase nice looking replacement bolts for the hub cover? Stainless steel maybe? After the rebuild, I have these pretty red and black painted hub cover and dial, and these ugly rusted up bolts holding it on...
Old Oct 26, 2008 | 06:24 PM
  #33
scuba's Avatar
Ha, lol.
nice.
Well downey supplied new face bolts with my gaskets and o rings.
But the ones that hold the hub to the body are not.
No biggie really.
Why dont you just pull up to a hardware store, pull one of each bolts, head inside and get replacements ?
And yes, i figured it out it must be something about the pressure inside the hub body that makes it do what its gotta do.
Old Oct 26, 2008 | 06:30 PM
  #34
if you know the thread pitch and diameter, you can get nearly anything you want, powder coated, etc...
if you're looking for stainless, first place I'd look is a fastenal dealer.
Old Oct 26, 2008 | 06:32 PM
  #35
Oh, there's a Fastenal about 3 minutes down the road from me! I may have to pay them a visit tomorrow after work, and step in with a bolt in my hand
thanks man!
Old Oct 26, 2008 | 06:39 PM
  #36
scuba's Avatar
nauuuahhhh
Old Oct 26, 2008 | 06:44 PM
  #37
nauuuahhhh
what the hell, lol
Old Oct 26, 2008 | 07:00 PM
  #38
scuba's Avatar
...like.... duhhh.....
only, with a wetaaaded guy holding his arm up to his chest
:X
Old Oct 26, 2008 | 07:07 PM
  #39
space-junk's Avatar
^ Thats horrible... lol...
Old Oct 26, 2008 | 07:49 PM
  #40
oh, lmao, ok then...
