sbc with TBI into 88 yota
Old Dec 4, 2012 | 01:40 PM
Tennessee's Avatar
I'm a newbie at the F.I. setup, and i was wondering if anyone can give me some advice? im installing a 350/400th/np208/danna 44 front corp.12 in rear in my 88 yota and i would like to have it tbi. thanks for your help
Old Dec 4, 2012 | 02:07 PM
Pat8942's Avatar
Wire harness and ECU from a TBI truck, the trans doesn't need any inputs from sensors to shift, but you will have to get a speed sensor for it if you want to use a speedo and the ECU uses Speed sensor signal to control idle during coast , similar to a dashpot.
Old Dec 4, 2012 | 02:58 PM
Tennessee's Avatar
ok thanks, what is a speed sensor signal? where is it located and where can i buy it at? i dont know what a dashpot is. how can i do the fuel system? will i need to hook up any cam or knock sensors? or o2 sensors
Old Dec 4, 2012 | 02:59 PM
Tennessee's Avatar
sorry for all the questions, im trying to get it ready for a benefit ride.
Old Dec 4, 2012 | 03:06 PM
fillsrunner4's Avatar
call Painless
Old Dec 4, 2012 | 03:16 PM
Tennessee's Avatar
i would but im on a budget, i can get the tbi wiring harness and computer out the door at salvage yard for 133.00 bucks
Old Dec 5, 2012 | 08:22 AM
timothy47129's Avatar
You can get speedometer sender adapter that makes the cable drive speedo off the 400 convert into the electronic signal you need for the tbi.I belive summit racing has them and i know painless does.
JonG85
Jan 18, 2023 04:31 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Ditch Doc
Oct 27, 2015 03:20 PM
shredder4286
Oct 1, 2015 01:09 PM
