sas pickup front end vibration
Old Nov 18, 2011 | 05:23 PM
1991yota's Avatar
Here is the problem, my driveshaft(front end) vibrates horribly. I have TG long splines and it was professionally built by six states. The vibrating is only really bad when the hubs are locked in AND the t case is in 4wd. For example, if I have the hubs locked in and the t case is in 2wd(driveline still spinning), the vibration is very small. Or vise versa, the hubs are unlocked and the t case is in 4wd. Can anyone help me out??
Old Nov 18, 2011 | 05:37 PM
waskillywabbit's Avatar
Sounds like bad pinion angle.
:wabbit2:
Old Nov 18, 2011 | 05:55 PM
1991yota's Avatar
The angle at the pinion is better than the one at the t case. It has single joints on each end, but I have heard of people running them like that without issues.
Old Nov 18, 2011 | 06:21 PM
dropzone's Avatar
Fossilized
Trail-gear flat out states "This product is a heavy duty replacement part and is not recommended for use on the street."
when I had my driveshaft built by http://drivelinetech.com/home.php Brian said that the T-G shafts could not be balanced properly..
Old Nov 18, 2011 | 06:28 PM
1991yota's Avatar
Ya, I know, but I feel it in 1st gear in low, thats rediculous
Old Nov 19, 2011 | 04:25 AM
Do you KNOW it is the driveshaft?
:wabbit2:
Old Nov 19, 2011 | 08:07 AM
1991yota's Avatar
Im pretty positive, but the thing is is that it only vibrates bad when the hubs and t case is locked in, this kinda makes me think it could be front end slop? I also have a v6 diff in the front, i dont know if that messes things up? Opinions??
truckmike26
Jul 24, 2024 10:24 AM
Daneums
Jun 29, 2015 06:38 AM
miceal383
Jun 29, 2015 12:27 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
