Rough idle on 91 3.0
Old Apr 21, 2008 | 08:09 PM
91YotaExcab's Avatar
The engine is running like crap up to about 2000 rpm and will still hesitate when past that when i hit the gas. i have replaced the plugs, wires, cap, rotor, both belt and the fuel filter. it has 97k miles and just started doin this a couple days ago... anyone got any thoughts that could help me out?
Old Apr 21, 2008 | 08:13 PM
toytech76's Avatar
check your compression
Old Apr 21, 2008 | 08:16 PM
keithdphan's Avatar
check timing
Old Apr 21, 2008 | 08:20 PM
i should add that it onlys does this after it is warmed up when i first start it it doesent do it
Crawdad's Avatar
And if both of those are in check run some Seafoam through it, and some in the gas tank.
Old Apr 21, 2008 | 08:24 PM
keithdphan's Avatar
check tps, then if its okay check timing.
Old Apr 21, 2008 | 08:28 PM
how would i "check" the tps what would i be looking for if somehting is wrong with it and where could i find it?
Old Apr 21, 2008 | 08:44 PM
keithdphan's Avatar
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Apr 22, 2008 | 04:53 AM
toytech76's Avatar
your tps and timing arnt going to make it run rough after warming up. You probably have a tight valve. You need a comp test
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
tomczaksdiesel
Jul 26, 2015 10:35 PM
