Roof rack Mounts for 2nd Generation 4runners
Old Nov 23, 2013 | 10:22 AM
1985eXtraCab4x4's Avatar
Yes, just as the title says I'm looking for a solid options for a heavy duty roof rack mounts for my 91 4runner. As the pics show there is no moon roof conflict and I want to be able to possibly do a roof camper and I want to utilizes the full length of the roof. Since I want to go full roof length and max weight it would probably be best to skip out on a junk yard retro fit of a stock rack.
In my local area I have on 2 separate occasions seen a 2nd gen 4runner with full length anchor rails running the full length of the recess. They are being used as work trucks and hauling ladders. Each time I see these I'm not in a situation to chase down the vehicle for a closer look.
I've done numerous Google searches and have not, as of yet, come up with any solid leads.
Old Nov 24, 2013 | 06:01 AM
nortonian's Avatar
Thule makes rails that appear similar to the stock 4runner rails that are longer and can be cut to any length you want. I put a pair on the cap on my tacoma and they worked well with all the thule stuff I already had. The only problem I can see is that they come with nuts and bolts for mounting hardware, so you would have to remove the headlines to install. You could use sheet metal screws but I don't think that would be strong enough.
I have a Thule basket rack that had an extension to make the basket 6" long that I used to use on a suburban.
Old Nov 24, 2013 | 10:50 AM
theerroneouspenguin's Avatar
I'm actually thinking of just mocking some drawings up and welded a tube one on with notches for bungies and rope. The stock ones are crap and the Thule's can cost about the same as a tube one but are as strong as the stock ones.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
jon.r
Jul 11, 2015 03:34 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
