Rolled my truck need help figurin out whats wrong with engine.
Old 01-18-2009, 08:03 PM
abecedarian's Avatar
ever wonder why they put the wheels on the bottom?
Old 01-18-2009, 08:05 PM
swapped89's Avatar
no, but stuff happens
Old 01-18-2009, 08:09 PM
86Toyrunna's Avatar
so.. i was going to ask, any damage to steering components.. when i rolled my 85 i bowed my tie rod pretty good. how bad is the bed.. thats the second rollover thats beds seen to lol us kids from Boring sure know how to abuse our toys huh lol
Old 01-18-2009, 08:10 PM
stuff is what happens when the wheels go up into the fenderwell more than you thought they should.
oh...
... the wheels are on the bottom because they roll better than the body does.
Old 01-18-2009, 08:12 PM
  #25
86Toyrunna's Avatar
i dunno abe.. if your going fast enough bodys roll pretty dang well .. just not as smooth as tires do lol
Old 01-18-2009, 08:13 PM
  #26
ozziesironmanoffroad's Avatar
i dunno when i rolled mine, it was upside down for 3 hours, then we got it back over and started it right up. smoked a lot at first, but then smoothed out. hell its ran even better ever since.. my theory is that a lot of oil got into the top end, thus lubricating the hell out of the engine... LOL.
Old 01-18-2009, 08:17 PM
  #27
swapped89's Avatar
ozzie i think yer a genious. hopefully she fires tomoro when i turn the key. after letting it blow oil for a bit. there was oil in the throttle body and everything probably the plenum to but im hopin i can just run it. quite the mess.
Old 01-18-2009, 08:18 PM
  #28
TAKE OUT THE PLUGS. i got lucky, depending on your situation, you could mess up your engine.
Old 01-18-2009, 08:24 PM
  #29
swapped89's Avatar
i did take the plugs out after i tried turn it over once before anything and not much happened sept a backfire sound. hope it didnt mess anything up. i dont think the starter could turn strong enough to hurt the internals of the motor. the battery was pretty dead after lettin the alarm go off all night in tow yard.
Old 01-19-2009, 04:44 AM
  #30
id turn the engine by hand...it should turn over EASILY
Old 01-19-2009, 07:32 AM
  #31
swapped89's Avatar
good idea. thanks again
Old 01-19-2009, 03:50 PM
  #32
merace19's Avatar
A starter is more than strong enough to bend those rods. But you may have got lucky with a dieing battery. Check the water level in battery if you have one that still needs it.
Old 01-22-2009, 10:06 AM
  #33
swapped89's Avatar
She is alive.I turned the cranshaft over with a wrench oil came out three cylinders but i gotem pretty clean. Used a whole can of carb cleaner in the cylinders. changed oil and filter. And put in some new NGK plugs she fired right up. now i just gotta straighten the cab, get it to hold a windshield.
can someone tell me how to copy an image from my pictures and post it on one of these replies ive tried everything i know and it just keeps commin out as jibberish.
Gamble_STi
06-27-2015 07:54 PM
Crazy_Guy97
12
06-24-2015 04:02 PM
ACZR
06-23-2015 07:55 PM
saphirekosmos
06-22-2015 10:26 AM
Quick Reply: Rolled my truck need help figurin out whats wrong with engine.
