RN, VZN, etc. nomenclature
Old Jan 26, 2007 | 01:19 PM
geoff's Avatar
I've seen references to RN, YN, VZN referring to various pickups and 4Runners. What do these mean? I was looking at a service manual on ebay that was for a VZN, but the seller said it applied to the 6 cylinder models. Sorry if this is a newbie question, but I've had my truck since new for over 19 years and just saw these terms recently. I couldn't find anything searching this site, or in the Haynes or Chilton manual
Old Jan 26, 2007 | 01:40 PM
jht3's Avatar
i believe that refers to the VIN #. it tells you where it was built, what engine was installed, etc. for instance, my '95 4runner V6 built in Japan starts with JT3VZN...or something
Old Jan 26, 2007 | 09:05 PM
BC Rider's Avatar
As usual 4crawler has the answer:
http://www.4crawler.com/4x4/ToyVIN.shtml
Old Jan 26, 2007 | 09:07 PM
BC Rider's Avatar
If you want info on what the engine designation means here is a good reference
http://en.wikipedia.org/wiki/List_of_Toyota_engines
Old Jan 26, 2007 | 11:11 PM
geoff's Avatar
Thanks for the inputs. I now know what some of these codes mean. I couldn't find a definitive guide to decoding my VIN, but have pieced enough together to make some sense out of it. My 1988 pickup VIN JT4RN50R5J5XXXXXXX means:
J = Japan (country of origin)
T = Toyota
4 = Truck
RN50 = chassis code, 2WD regular cab regular box set up for 22R/22RE engine
R = ?
5 = check digit
J = 1988 model year (I bought mine in 11/87)
5 = assembly plant (somewhere in Japan?)
At least now I know that anything that says VZN doesn't directly apply to my truck!
Toyota's own decoder at http://fleet.toyota.com/html/vin_decoder.asp doesn't work for the older models like mine
http://www.toyotareference.com/#TR had some more information
Old Jan 26, 2007 | 11:39 PM
4Rocker's Avatar
I believe that RN refers to trucks (or 4Runners) with a R series 4cyl (eg 22R or 22RE), and VZN refers to the vehicles with a VZ series 6cyl (eg 3VZ-E). I think the number after the letters refers to the style of frame such as solid axle or ifs, or short wheelbase or long.
Old Jan 27, 2007 | 12:00 AM
geoff's Avatar
http://www.4x4wire.com/toyota/faq/vin/ clarified more!
The "vehicle description section" RN50R means:
R = 22R
N = Truck
Model 50:
5 = 4x2
0 = short wheelbase
Series/grade:
R = standard
This is consistent with the reality of my truck :bigclap:
Now I need to look at the ID plate under the hood to see if I've really got it correct
primordialbeast117
Dec 19, 2015 12:23 PM
voiddweller
Oct 2, 2015 07:47 AM
Odin
Sep 26, 2015 06:56 PM
Toys4parts
Sep 26, 2015 01:56 PM
user 82300
Sep 22, 2015 07:00 AM
