Rims And Tires Help
Old Jan 19, 2009 | 09:12 PM
myyota's Avatar
Rims And Tires Help
I asked this question in the tire and rim section but im not getting any help there, so i will ask it here. I have an 86 4Runner with a solid axle up front, it has 63'' chevy springs in the rear and 5'' trail gear springs in front, i want to run 37'' tires, something like 37 x 12.50 or 10.50-15`s, on steel rims, and i need to know what back spacing i need to go with for clearance and turning radius ?, any help or info is appreciated.
Old Jan 20, 2009 | 05:04 PM
myyota's Avatar
^^bump^^
Old Jan 20, 2009 | 05:09 PM
abecedarian's Avatar
what's your current tire size and backspacing?
Old Jan 20, 2009 | 06:23 PM
myyota's Avatar
Right now i just have some junk rims and tires on it so it can be rolled around in the shop, im sure you know the look, tires not much bigger than stock on a lifted truck. thats why im looking for some info or pictures.
Old Jan 20, 2009 | 07:30 PM
toyminator2000's Avatar
3.5 to 3.75 inches is what you want. Any more and your tires will rub your leaf springs when turning.
Old Jan 20, 2009 | 08:08 PM
myyota's Avatar
Ok, if i go with 37'' tires (37x12.50-15 tires) and steel rims with 3.75 back spacing, will that work on my 4Runner as far as not hitting the springs when i make a full lock turn right or left ?.
Old Jan 20, 2009 | 11:42 PM
It may touch slightly. I have 37x13-15 boggers on 15x9 3.75 and they will slighty rub the metal band that holds the leaves together. I thinks thats just because the lugs on the boggers stick out farther than most tires.
chukarhunt
Dec 8, 2019 11:39 AM
Jamie4runner2000
Jun 20, 2016 09:13 AM
jpluddite
Oct 2, 2015 03:49 PM
sphealy
Sep 3, 2015 07:55 PM
Yotoder865
Jul 9, 2015 07:51 PM
