replacement springs for my 1989 4Runner?
Old Nov 4, 2022 | 12:52 AM
lledwod's Avatar
I've spent a lot of time googling this and not getting anywhere. I have about 1.5 inches travel left at the rear and bottoming out all the time now, even with empty truck. I had decided to order OME cs009r springs, (2"lift) but then I have read that they lift too high ( I want to stay stock height) and that they are stiff ride? Should I try add a leaf? I have rear coils out of a 3rd gen; should I try the Zuk before I spend money? I just want a good daily driver, and the rest of the truck is in great shape. Any suggestions from experienced owners would be greatly appreciated! Thank you. Jonathan
Old Nov 4, 2022 | 03:05 AM
PickleRick81's Avatar
The ome are high and if used with stock shackle they may sit at a rough riding straight up and down angle.
I took one leave out of each and have about a 1.5 over stock shackle.
Up front I have 2 inch ball joint spacer lift.
My wheel wheels gap is 9 inches front and 10.5 in back with a soft top. 285 70 17 tires
Remove two inches from that for a rig without a 2 inch body lift.
If you're near upstate SC I have some springs I pulled apart, they still had good arch. I cleaned, painted and did an aal. Sits about 1.5 inches over stock, 2 to 2.5 if you're currently squatting.
I've never ridden a stock classic tr4 but compared to my excursion, my past fjs and lifted disco 2 it rides fine on the ome
Old Nov 6, 2022 | 06:26 AM
lledwod's Avatar
Hmmmm. Thanks for you comment. And thanks for your offer, I live in the north-west though, 30 miles from the Alaska border in Canadas Yukon. Maybe I'll try to build my own pack out of springs I've got. It doesn't seem right to buy a product with a name like OME and have to modify it ....
Old Nov 6, 2022 | 06:48 AM
The ome kit is designed to handle weight. Swing out tire carrier, Jerry can holders, ARB built bumper, secondary fuel tank and enough gear to overland for a month.
That being said its quicker to remove a rear spring from each pack than it is to readjust your ifs front suspension after cranking a torsion bar.
I have a soft top and tube rear bumper by 4x4 innovation. It has a 285 70 17 spare on the swing out tire carrier. The only thing in the back is a set of 10s in a box. With my tires and a 2 inch body lift I have about 10 inches of wheel gap in the rear, the tires will will hit the bump stops even with 1.5 inch wheel spacers before eating a fender.
My only issue is these leaf packs don't flex well because they are so stiff. Chevy springs would be better for the off road enthusiast
T these ome springs are stiff.
Old Nov 6, 2022 | 07:48 AM
aztoyman's Avatar
I'm running 63" Chevy springs on my 88. (not a 4Runner though) I bought the U-bolt flip kit and rear shackle mount and fabbed my own front mount and shackles. You can buy complete Chevy spring swap kits if you prefer. What a difference in ride and flex compared to the short stiff stock springs. I did play around with the spring pack to get it how I wanted. Springs are cheap and easy to find. Well ,where I live anyway.
Had a new 86 4Runner that sagged the rear springs out. Had the original springs re-arched and it was back to the original stiff ride. When they sagged out again we bought so called stock replacement springs. Rode like a stink bug for 6 months and then back to the normal stiff ride. Wish the Chevy spring swap was known back then.
Old Nov 6, 2022 | 09:15 AM
lledwod's Avatar
Well I'll see if I can find 63" springs, this sounds like a very realistic option I had not considered. Looks like they may fill the 'stock ride height' and 'ride quality top priority' bill!
Thanks, Jonathan
Old Nov 6, 2022 | 10:28 AM
Jimkola's Avatar
YT Community Team
5 Year Member
My 1987 sagged in the back, and the P.O. had but aluminum blocks at the rear to compensate. Worked, but created a few other not-so-good issues.
So I got a set of OME springs. As close to stock as I could.
They raised the back more than I liked, and made the ride rough as heck. I could have raised the front torsion bars, but that would have just put stress on the upper ball joints, and made the ride even rougher.
So I pulled them and disassembled. I then dragged out my oem spring packs and did the same. I removed the second longest leaf from the OME and swapped out the equivalent leaf in the OEM pack. I installed the original OEM packs back on the vehicle, now with one new leaf. It's now only slightly higher than stock, and the ride is vastly better over the OME .
So, I took an expensive and convoluted path to essentially add a leaf spring.
I know people rave about OME, and the price is attractive. Just too stiff for my liking.
Pete-87-22r
Jun 16, 2013 12:19 AM
SaintLarryZonka
Feb 20, 2009 05:46 AM
norflaballer
10
Oct 28, 2007 08:37 AM
Riverboy
May 1, 2006 04:56 PM
HuntRunner
Feb 18, 2005 02:38 PM
