removing complete ADD system?
Old May 11, 2008 | 06:02 AM
HAVOC's Avatar
I have a 1995 3.0 pickup. It has the ADD system on it. I would like to completely remove everything associated with it, including actuator, vacuum lines, and the parts from the driver side axle tube.
I'll be pulling the engine to rebuild it (rod knock), and I'll be removing the parts then. I have a 1989 pickup with manual hubs. I guess I could use parts from that diff, but the 89 has 4:10 and the 95 has 4:56. (I'll be using 4:56).
Can I just unbolt the diver side axle tube from the 89 front diff and bolt it to the 95 diff? I'll use the hubs from the 89, but I also have hubs from a 83 pickup. SA hubs wont work on a IFS frontend, correct?
Old May 11, 2008 | 06:12 AM
crolison's Avatar
yes you just have to bolt up the manual hub tube to the 4.56diff, and your correct the sa hubs wont work.
Old May 11, 2008 | 06:23 AM
toomanytoyotas's Avatar
Have you read this write up:
http://www.4x4wire.com/toyota/tech/add/
I did this on my previous 4Runner and it worked great. Seems like a lot less hassle than swapping.
Old May 11, 2008 | 06:34 AM
HAVOC's Avatar
Yes, but I have all the parts to do the swap already. The 95 will be replacing my 89 as my daily driver. I also have to pull the L/F axle to replace a C/V boot, so that's more parts out of the way.
Old May 11, 2008 | 07:44 AM
mt_goat's Avatar
Correct, if you want to sell those shoot me a PM.
I did the ADD dissable in that 4X4wire writeup, its very easy.
Old May 11, 2008 | 01:27 PM
HAVOC's Avatar
Nope. If I ever do a SAS, I'll have them already, I've seen how much they cost.
I'll defeat the ADD, but I want the parts gone. I don't want parts left on the truck they don't serve a purpose.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
bryan34w
Jul 6, 2015 05:53 PM
HRDC0R19
Jul 5, 2015 06:43 PM
