Relay rod replacement - used OE or aftermarket?
Old Jul 19, 2011 | 06:38 PM
RatLabGuy's Avatar
'89 4Runner. My relay rod is bent. Not dramatically but enough that I can see it, and w/ the abuse this thing gets it must be replaced.
Is there an upgrade/stronger aftermarket one for the IFS steering?
If not, what is the conventional wisdom on the standard (beck/arnley etc) replacements? Other option is a used OE one. I actually have an old one in the garage, but I don't know what year its off of... e.g. could be one of the recalled ones...
Old Jul 19, 2011 | 07:12 PM
Shoua's Avatar
And you've already gotten the recall performed?
If so, then you're on your own. You'll have to fork over the money for a new one. I, for one, wouldn't trust an old used one. You just never know.....
I've never heard of a stronger aftermarket one. Guys?
Old Jul 19, 2011 | 07:28 PM
RatLabGuy's Avatar
My '89 4Runner isn't covered by the recall.
Yes, I'm "on my own". I bent it, it's up to me to replace it....
Yeah, I don't trust an old used one, I just keep it as an emergency spare.
There are several beefy ones that go along w/ hi-steer etc for SA or SASed trucks, but i need a replacement for stock IFS.
Old Jul 24, 2011 | 06:30 PM
RatLabGuy's Avatar
OK I'm thinking seriously about beefing an old OE one by sleeving it w/ .250 DOM, w/ ID that matches the OD of the main shaft of the relay rod.
I figure I'll have to cut it in the middle, slip teh halves into the tube so the yre-join up in teh middle, then weld around the ends so it's all held together again. Perhaps also dril la few holes in the sleeve DOM to use for plug-welds ensuring it's all 1 solid piece.
Thoughts on this?
Seen some discussion in the past on home-made upgrades (AxleIke...). Also - whats the consensus, is this rod cast or forged? I have no experience welding w/ cast...
Old Jul 24, 2011 | 07:04 PM
Greg_Canada's Avatar
total chaos makes a beefed up relay rod.
Old Jul 24, 2011 | 08:29 PM
RatLabGuy's Avatar
Yes... and it is rediculously expensive for what you are actually getting (just a relay rod for $500). If I had that kind of coin to drop, I'd be paying for fabrication of a whole new setup...
bigjstang
Jun 2, 2025 03:56 PM
Road Bull
Oct 10, 2015 04:55 PM
Sep 4, 2015 09:27 AM
colinmil
Jul 6, 2015 04:03 PM
Suprarossa
Jul 6, 2015 05:21 AM
