Recommrndations needed: Vendor for exhaust system
I am trying to find a vendor for a muffler and downstream pipe. I don't want to deal with a stealer or "muffler shop." I just want to buy the parts and install them. I bought a BRexhaust kit from Autozone for my wife's Matrix and it was easy to find the right parts, and it fit fine. I am getting very frustrated trying to find the parts for the truck:
1994 extended cab pickup, 121.5" wheelbase, 2.4L 22RE engine, 4wd, 5 speed trans.
If you have bought from a vendor that made it easy to find the right exhaust system parts, please share that info. I am in Montana, but I don't mind ordering online.
Thanks!
Thanks!
When I did the exhaust on my '88 2wd I ordered parts from Rockauto. I ordered a pre-bent tailpipe to a V6 truck (2 inch instead of 1.75), a 2 inch Dynomax muffler, and used a straight piece of 2 inch pipe from the cat back to the muffler. I welded it myself and did not need to bend any tubing. It is not as good as a mandrel bent pipe or something from a quality exhaust shop, but it was quite cheap and works well. It has been working fine for me here in California, but if they salt the roads where you are then you would probably want something better. If you are looking for something more performance oriented, I know LC Engineering sells a complete system but I do not have any experience with it. Hope that helps!
I have a 1986 2WD x-cab short bed 5-speed. I am on my 2nd Bosal tailpipe/muffler assembly (Bosal #8127-05657445) 112.2 " Wheel base from Rock Auto. Seem to last ~150K miles Bolts up to the rear flange of the cat converter perfect fit. As were the dounut flex mounts support rods. Buy a gasket and it's a 30 minute job if the bolts and nuts aren't rusted. Mine weren't as last time I installed new stainless bolts, nuts and washers. My OCD said I had to do it. Did the front cat bolts while I was there.
I replaced the cat converter at 38 year mark usind a New Catalytic Converter- Walker 16-360 from Parts Geek. I tries 3 other brands and all of them garbage with misaligned flanges. This walker fit perfect and another 30 minute job.
toyota4x4907
Dec 3, 2008 08:29 PM
