Rear end help.........
Old Jul 26, 2007 | 05:17 PM
My954Runner's Avatar
Ok, I am removing my rear end chunk in anticipation of my "new" rear end....
On the top of the chunk there is a cable that is attached to the top of the housing......
How do I get this off???? I removed the bolt that was screwed thru it, but it still won't come off.....
What is this for?
Thanks for the help.......
Chad
Old Jul 26, 2007 | 05:37 PM
mr toytech's Avatar
sounds like the e-brake cable but a pic would help
Old Jul 26, 2007 | 05:50 PM
I'll go shoot a pic...but I don't think its the ebrake...it goes into the housing....
Old Jul 26, 2007 | 06:00 PM
OK, it is the cable with the silver cover on the middle right of the pic...
Old Jul 26, 2007 | 07:38 PM
leebee's Avatar
iirc, that should be your 'rear abs' sensor. do a quick search on it and you will find out how to get it out.
lee
Old Jul 26, 2007 | 08:16 PM
Kaleb's Avatar
Flat head screw driver will pry it out fairly easily.
Old Jul 27, 2007 | 03:02 AM
Thats what I thought it was last nite, but it was late, so I will give it another shot when I get home tonight....
Thanks for the help
Chad
Old Jul 27, 2007 | 06:17 AM
GSGALLANT's Avatar
Yep, a flat screwdriver and a bit of patience should get it out in one piece. The sensor-to-housing interface is sealed by an o-ring, which is mounted on the body of the sensor itself, and will come out when you remove the sensor.
Old Jul 27, 2007 | 05:46 PM
toyota_mdt_tech's Avatar
Rear wheel ABS speed sensor. It will come out, but they can break. Twist it and pull. I have had them break also.
Old Jul 27, 2007 | 05:49 PM
frodin1's Avatar
PB blaster is your friend. I highly recommend it.
the1998sr5
15
Jul 14, 2020 08:35 PM
Daneums
Aug 20, 2015 05:36 AM
rondogracing
Jul 14, 2015 07:00 PM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
